Ana içeriğe geç
How to Clean the InFocus X2 Lamp Housing Screens
Neye ihtiyacın var
  1. How to Clean the InFocus X2 Lamp Housing Screens, Open the Lamp Door: adım 1, 3 resimden 1. How to Clean the InFocus X2 Lamp Housing Screens, Open the Lamp Door: adım 1, 3 resimden 2. How to Clean the InFocus X2 Lamp Housing Screens, Open the Lamp Door: adım 1, 3 resimden 3.
    • Be sure that the projector is turned off, unplugged, and has cooled for at least 30 seconds.
    • Insert the Jimmy into one of the two notches on the lamp door's top edge.
    • Then use light force on the Jimmy to pry the latch away from the door.
    • If necessary, insert the Jimmy into the second latch and separate it from the projector.
    • Remove the door away from the projector by hand.
  2. How to Clean the InFocus X2 Lamp Housing Screens, Disconnect the Lamp: adım 2, 3 resimden 1. How to Clean the InFocus X2 Lamp Housing Screens, Disconnect the Lamp: adım 2, 3 resimden 2. How to Clean the InFocus X2 Lamp Housing Screens, Disconnect the Lamp: adım 2, 3 resimden 3.
    • Gently disconnect the lamp from the projector by using your thumb and forefinger to pinch on the white tab on the plug.
    • Then pull the plug away from the projector.
  3. How to Clean the InFocus X2 Lamp Housing Screens, Unscrew the Lamp from the Projector: adım 3, 3 resimden 1. How to Clean the InFocus X2 Lamp Housing Screens, Unscrew the Lamp from the Projector: adım 3, 3 resimden 2. How to Clean the InFocus X2 Lamp Housing Screens, Unscrew the Lamp from the Projector: adım 3, 3 resimden 3.
    • Use a Phillips #4 screwdriver or driver with the Phillips #4 head to unscrew the two 0.6 mm diameter brass screws from the lamp's housing.
    • For the lower screw, ensure it remains in the hole in the lamp assembly and it does not fall into the projector. If it falls in the projector, use a magnetized screw bit or a small magnet to pick it up and remove it.
  4. How to Clean the InFocus X2 Lamp Housing Screens, Remove the Old Lamp: adım 4, 1 resimden 1.
    • Pull on the bottom plastic tab and remove the lamp by hand.
  5. How to Clean the InFocus X2 Lamp Housing Screens, Insert the New Lamp: adım 5, 1 resimden 1.
    • Insert the replacement lamp into the projector.
  6. How to Clean the InFocus X2 Lamp Housing Screens, Cleaning the Dirty Screens: adım 6, 2 resimden 1. How to Clean the InFocus X2 Lamp Housing Screens, Cleaning the Dirty Screens: adım 6, 2 resimden 2.
    • Use a vacuum cleaner to gently suck up the dust on the front and the back Lamp Housing screens.
Sonuç
Ekli Belgeler
Paulina Duarte
553 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013 üyesi
UMASSD-GULBRANDSEN-F13S1G3
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 141
