Ana içeriğe geç
How to Clean the Keurig K75 Platinum Brewing System Needle
Neye ihtiyacın var
  1. How to Clean the Keurig K75 Platinum Brewing System Needle, How to Clean the Keurig K75 Platinum Brewing System Needle: adım 1, 1 resimden 1.
    • Before needle repair, make sure the brewer is disconnected from any power outlet.
    • Lift the handle to open the top of the brewer.
    • There are two sharp needles that puncture the K-Cup pack. One is above the K-Cup holder and the other is in the bottom of the holder. Be careful when cleaning the top needle.
  2. How to Clean the Keurig K75 Platinum Brewing System Needle: adım 2, 1 resimden 1.
    • Bend a paperclip to create a vertical metal piece. This is used to clean the top needle.
  3. How to Clean the Keurig K75 Platinum Brewing System Needle: adım 3, 1 resimden 1.
    • Insert a paper clip into the exit needle to loosen the debris and push it out.
    • Repeat this action until the debris is cleared from the top needle.
    • All external pieces of the brewer are dishwasher safe.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alexander Vo
94 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-2, Maness Winter 2013 Cal Poly, Team 20-2, Maness Winter 2013 üyesi
CPSU-MANESS-W13S20G2
4 Üyeler
6 adet Kılavuz yazıldı
9 Yorum
must be something else on mine. i have cleaned out with paper clip 3 times and still no water comes out.
jjthdj - Yanıt
try descaling it
marymckercher -
Worked great for mine just now. I picked up a used B20 Platinum at a Garage Sale yesterday for only $10 super easy to clean needle & now it works great!! Thanks OP!!
ronald944 - Yanıt
My husband keeps wanting to buy me something new every time the old one doesn't work, well I am old fashioned and will do anything I can to save money. Thank goodness this worked than you so much.
Wendy Clark - Yanıt
How about the needle at the bottom of the holder?
tahoejb - Yanıt
Clean that too. It can’t hurt.
LARRY RODAMMER - Yanıt
I have used filter water ALL WAYS, in my model B 70 I made a cup this AM. I did not need it on any more so shut it down. Or turn off the power switch. Now that not ready light keep blinking. I done every suggestion on, line. Any help. ????????
jrschex - Yanıt
where can i get a new silicone gasket
Bill Blogna - Yanıt
Amazon or ebay
marymckercher -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 37
Her zaman: 21,918
