Giriş
If you have a hole in your sock and want to fix it, this guide will help repair it through a simple method called darning.
Darning a hole in a sock provides a different outcome than simply sewing up the hole. When you darn a sock, it acts as a replacement for the missing fabric. So, if you have suitable thread types, you can create cool patchwork socks.
A darning mushroom is one of the tools listed. These can be found on Amazon or whichever website you use to purchase goods. If you do not have a darning mushroom or wish to avoid purchasing one, substitutes include tennis balls, light bulbs, or, like in my guide, a water bottle. Essentially, you will need an object inside the sock to stretch out the hole.
Neye ihtiyacın var
Insert a darning egg (or substitute object) into the sock until the hole is stretched out.
Bir başkası bu kılavuzu tamamladı.
