Ana içeriğe geç
How to Deep Clean AirPods 3 (buds only)
Neye ihtiyacın var
  1. How to Deep Clean AirPods 3 (buds only), Light surface clean: adım 1, 2 resimden 1. How to Deep Clean AirPods 3 (buds only), Light surface clean: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    Microfiber Cleaning Cloths
    $3.99
    • Get your microfiber cloth (or any softer cloth) and gently wipe the white surface, and the sensor on the AirPods. You can also put a very little amount of your isopropyl alcohol on the rag
    • After this very carefully rub the mesh parts of the bud (with a dry part of the cloth) to free-up some of the earwax or dirt
  2. How to Deep Clean AirPods 3 (buds only), Getting around the speaker mesh: adım 2, 1 resimden 1.
    • Now grab your spudger and carefully, slowly work your way around that lip where the mesh sits to get or earwax there
  3. How to Deep Clean AirPods 3 (buds only), Getting inside the mesh: adım 3, 2 resimden 1. How to Deep Clean AirPods 3 (buds only), Getting inside the mesh: adım 3, 2 resimden 2.
    • Now take your Q-Tip and put it inside the rag, so the rag has a nice point this allowed the cloth to have a strong tip to get inside the mesh
    • DO NOT USE THE Q-TIP WITHOUT THE CLOTH OVER IT THE COTTON FROM THE TIP WILL GET STUCK IN YOUR AIRPODS MESH
    • Gently rub around in all directions inside the mesh to get earwax out, you can also use VERY little isopropyl alcohol to help DO AT OWN RISK
    • A really easy and good trick to see if its all gone is to take your bud and shine a light right in to the grill, and if you see a some shine there is still earwax left.
    • If there is more left repeat step 3, but please note you will not be able to get it perfect.
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
Colton Turner
534 İtibar
2 adet Kılavuz yazıldı
1Rehber Yorum
A few points:
- I personally like to use the https://www.target.com/p/apple-airpods-3... cleaning pen
- I do not use a rag, I also use more than a conservative amount of hydrogen peroxide instead of alcohol. This always cleans my airpods thoroughly. I just leave them with the grill down to let any liquid drain out.
Jessie Bell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 122
Son 30 gün: 757
Her zaman: 6,084
