Ana içeriğe geç
How to Disable Auto Boot
    1. How to Disable Auto Boot, How to Disable Auto Boot: adım 1, 3 resimden 1. How to Disable Auto Boot, How to Disable Auto Boot: adım 1, 3 resimden 2. How to Disable Auto Boot, How to Disable Auto Boot: adım 1, 3 resimden 3.
      • Power on your Mac and launch Terminal.
      • To launch Terminal, you can either use Spotlight Search or navigate to Applications / Utilities in Finder and double click the Terminal icon.
      FixBot'a Sor
      Yorum Ekle
    2. How to Disable Auto Boot: adım 2, 2 resimden 1. How to Disable Auto Boot: adım 2, 2 resimden 2.
      • Copy and paste the following command (or type it exactly) into Terminal:
      • sudo nvram AutoBoot=%00
      • Press [return].
      • Your [return] key may also be labeled ⏎ or [enter].
      • If you are prompted for an administrative password, type the password and press [return].
      • Your password will not be displayed in Terminal.
      FixBot'a Sor
      Yorum Ekle
    3. How to Disable Auto Boot: adım 3, 1 resimden 1.
      • You can now safely power down your Mac and remove the bottom case, without it accidentally powering on.
      • Remember, you must still disconnect the battery before servicing internal components.
      FixBot'a Sor
      Yorum Ekle
    4. How to Disable Auto Boot: adım 4, 3 resimden 1. How to Disable Auto Boot: adım 4, 3 resimden 2. How to Disable Auto Boot: adım 4, 3 resimden 3.
      • When your repair is complete and your Mac is successfully reassembled, you can re-enable the Auto Boot feature.
      • sudo nvram AutoBoot=%03
      • Press [return].
      • Alternatively, you may reset your Mac's NVRAM to re-enable Auto Boot.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Congrats! You're done.
76 farklı kişi bu kılavuzu tamamladı.
Jeff Suovanen
453.889 İtibar
259 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
48.534 adet Kılavuz yazıldı
29Kılavuz Yorumları
hello may i ask, how do u make it Jeff$? mine’s scarlet$ and i want to change it but idk how
srhshahdzan - Yanıt Paylaş
You change the your user/Homefolder name
Ben Capehart - Yanıt Paylaş
You do not need to change it for the command to work. But if you really do want to for a different reason, rename your home folder name.
Junaayd Shaikh - Yanıt Paylaş
I can’t type anything into the terminal…what am I doing wrong?
Linda Sussman - Yanıt Paylaş
HELP
it doesn’t work on MacBook Air><
my sister’s pro did work, thanks!! but mine can’t do so. what should I do???
Ching-Hsien Chou - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 55
Son 7 gün: 384
Son 30 gün: 1,640
Her zaman: 215,258
