Ana içeriğe geç
How to Disconnect a Car or Truck Battery
Neye ihtiyacın var
    1. How to Disconnect a Car or Truck Battery, How to Disconnect a Car or Truck Battery: adım 1, 3 resimden 1. How to Disconnect a Car or Truck Battery, How to Disconnect a Car or Truck Battery: adım 1, 3 resimden 2. How to Disconnect a Car or Truck Battery, How to Disconnect a Car or Truck Battery: adım 1, 3 resimden 3.
      • Before you begin, switch the ignition off and remove the key.
      • Make sure the transmission is in Park (or first gear if you have a manual gearbox) and that the parking brake is engaged.
      • Put on work gloves and safety goggles if you have them available.
      • In addition to being dirty, the battery contains corrosive agents and may release flammable gases.
      • Gloves can also help protect you from an unpleasant shock if you accidentally mishandle the battery.
      FixBot'a Sor
      Yorum Ekle
    2. How to Disconnect a Car or Truck Battery, Open the hood (bonnet): adım 2, 3 resimden 1. How to Disconnect a Car or Truck Battery, Open the hood (bonnet): adım 2, 3 resimden 2. How to Disconnect a Car or Truck Battery, Open the hood (bonnet): adım 2, 3 resimden 3.
      • Most motor vehicle batteries are located in the engine bay, under the hood (a.k.a. bonnet). If your battery is located elsewhere, skip to Step 5.
      • If you're not sure, simply continue reading.
      • Pull the hood release lever. It's usually located inside the car, near the steering wheel.
      FixBot'a Sor
      Yorum Ekle
    3. How to Disconnect a Car or Truck Battery: adım 3, 3 resimden 1. How to Disconnect a Car or Truck Battery: adım 3, 3 resimden 2. How to Disconnect a Car or Truck Battery: adım 3, 3 resimden 3.
      • Raise the hood by simultaneously lifting and pressing up on the hood latch release (usually located beneath the front edge of the hood, near the center or center-right).
      FixBot'a Sor
      Yorum Ekle
    4. How to Disconnect a Car or Truck Battery: adım 4, 3 resimden 1. How to Disconnect a Car or Truck Battery: adım 4, 3 resimden 2. How to Disconnect a Car or Truck Battery: adım 4, 3 resimden 3.
      • At this point, depending on the vehicle, your hood may raise and support itself automatically.
      • If not, use one hand to hold the hood open temporarily while securing the hood with the prop rod:
      • Lift one end of the prop rod up or out to release it from the front area of the engine bay.
      • Swing the end of the prop rod up and slide it into the cutout on the underside of the hood.
      • Make sure the hood is well secured before you let go with your other hand, or it may fall and injure you.
      FixBot'a Sor
      Yorum Ekle
    5. How to Disconnect a Car or Truck Battery: adım 5, 3 resimden 1. How to Disconnect a Car or Truck Battery: adım 5, 3 resimden 2. How to Disconnect a Car or Truck Battery: adım 5, 3 resimden 3.
      • Locate the battery. It's normally rectangular and roughly 8-14" across.
      • The battery may be easy to spot, or it may lie under a plastic cover—usually marked with positive (+) and/or negative (-) symbols.
      • On some models, the battery may be located in the trunk—usually under or behind the trunk lining. Look around or consult your owner's manual.
      FixBot'a Sor
      Yorum Ekle
    6. How to Disconnect a Car or Truck Battery: adım 6, 3 resimden 1. How to Disconnect a Car or Truck Battery: adım 6, 3 resimden 2. How to Disconnect a Car or Truck Battery: adım 6, 3 resimden 3.
      • Using a correctly sized wrench or socket, loosen the nut/bolt securing the cable on the negative battery terminal.
      • Always disconnect the negative cable first (before removing the positive cable).
      • The negative terminal may be marked with a minus (-) symbol, or it may be unmarked. The positive terminal is almost always marked with a plus (+) symbol, often in red.
      • If the nut or bolt spins without loosening, it may be necessary to counter-hold the opposite side with a second wrench or socket.
      FixBot'a Sor
      Yorum Ekle
    7. How to Disconnect a Car or Truck Battery: adım 7, 2 resimden 1. How to Disconnect a Car or Truck Battery: adım 7, 2 resimden 2.
      • Remove the cable from the negative battery terminal.
      • When connecting the battery, it is advised to roughen up the battery terminals and clean the cable clamp beforehand.
      • Upon reconnecting the battery, make sure to seal the pole connections with an appropriate terminal grease or terminal spray.
      FixBot'a Sor
      Yorum Ekle
    8. How to Disconnect a Car or Truck Battery: adım 8, 2 resimden 1. How to Disconnect a Car or Truck Battery: adım 8, 2 resimden 2.
      • Prevent the cable from making accidental contact with the terminal by pushing it aside and/or wrapping the cable clamp with a dry rag.
      FixBot'a Sor
      Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Jeff Suovanen
454.165 İtibar
259 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
78.608 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 161
Son 30 gün: 647
Her zaman: 32,475
