Giriş
Use this guide to drill a keyring hole in your AirTag.
Attempt this procedure at your own risk. Drilling through your AirTag may damage its functionality and will negate the AirTag’s IP67 water resistance rating.
Be Careful - This is not a necessary addition, as cheap 3rd party keyrings are available on sites like Amazon. Do this at your own expense, as you may end up breaking the device and Apple will not accept this under the warranty.
Neye ihtiyacın var
Use both of your thumbs to push down on the battery compartment door.
Rotate the battery compartment door counter-clockwise to unlatch it from the frame.
Lift up the battery compartment door to remove it.
To avoid damaging the internal components, drill through the space next to a clip.
Rotate the AirTag so that the CE marking is upright.
Use a marker or pen to draw a dot where you want to drill the keyring hole.
Use a metal file to remove burrs and sharp edges from the keyring hole.
Remove any remaining plastic particles on the AirTag before installing the keyring.
To reassemble your device, follow these instructions in reverse order starting at step 4.
Repair didn’t go as planned? Ask our AirTag Answers community for help.
10 farklı kişi bu kılavuzu tamamladı.
8 Yorum
ifixit has been an incredible resource for me (and the world!) since about 2006, I believe. And although, technically, me replacing a Mac’s hard drive may void my warranty, THIS particular project is just so darned unnecessary and a guarantee to void any warranty. I have two AirTags. One is in a Belkin protector, the other in a silicon fob from Amazon. I’ll continue to recommend ifixit to my audiences - but this project is just, well, weird. How about a fix for the AirTags NOT accepting a Duracell 2023 battery?
Isn’t also just weird yet trademark Apple to not provide any accessory with the product that allows you to hold it or attach it to any keyring without a separate purchase?
well, this is a cheap alternative to give apple the same money you already gave them for the tag, but i still prefer third party accesories.
I can’t think of any reason to do this.
No points given.
there is no reason to drill a hole in your airtag - just buy a keyring accessory for it instead of risking breaking your airtag. I agree donald.
tayola -
