Ana içeriğe geç
How to Dry Wet Canon PowerShot SD850 IS Camera Components
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. How to Dry Wet Canon PowerShot SD850 IS Camera Components, Battery: adım 1, 1 resimden 1.
    • Identify the battery port on the underside of the camera.
  2. How to Dry Wet Canon PowerShot SD850 IS Camera Components: adım 2, 2 resimden 1. How to Dry Wet Canon PowerShot SD850 IS Camera Components: adım 2, 2 resimden 2.
    • Using your thumb, slide the port to the right and release.
  3. How to Dry Wet Canon PowerShot SD850 IS Camera Components: adım 3, 1 resimden 1.
    • Remove the battery.
  4. How to Dry Wet Canon PowerShot SD850 IS Camera Components, Housing: adım 4, 3 resimden 1. How to Dry Wet Canon PowerShot SD850 IS Camera Components, Housing: adım 4, 3 resimden 2. How to Dry Wet Canon PowerShot SD850 IS Camera Components, Housing: adım 4, 3 resimden 3.
    • To avoid severe electric shock do not remove or tamper with internal camera flash components. An electrical capacitor is attached to the flash that can discharge if contact is made.
    • Remove the two side screws, indicated by the red circles, using a Phillips #00 screwdriver.
    • Remove the screw in the battery port, indicated by the blue circle, again using a Phillips #00 screwdriver.
    • Remove the front face by gently peeling the housing away from the camera.
  5. How to Dry Wet Canon PowerShot SD850 IS Camera Components: adım 5, 3 resimden 1. How to Dry Wet Canon PowerShot SD850 IS Camera Components: adım 5, 3 resimden 2. How to Dry Wet Canon PowerShot SD850 IS Camera Components: adım 5, 3 resimden 3.
    • Remove the back face by using a spudger to lift the tab highlighted in yellow
    • Pivot the back face clockwise as seen in the second photo.
  6. How to Dry Wet Canon PowerShot SD850 IS Camera Components: adım 6, 2 resimden 1. How to Dry Wet Canon PowerShot SD850 IS Camera Components: adım 6, 2 resimden 2.
    • Remove the A/V port cover [no tools are necessary]
  7. How to Dry Wet Canon PowerShot SD850 IS Camera Components, How to Dry Wet Canon PowerShot SD850 IS Camera Components: adım 7, 2 resimden 1. How to Dry Wet Canon PowerShot SD850 IS Camera Components, How to Dry Wet Canon PowerShot SD850 IS Camera Components: adım 7, 2 resimden 2.
    • Use compressed air to dry off camera's internal components.
    • Use caution when performing this step. Compressed air could possibly damage components if sprayed directly at connections or other sensitive areas.
Sonuç
iDeleted
2.101 İtibar
39 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 2,535
