Ana içeriğe geç
How to Fix A Broken Makeup Compact Without Alcohol
Neye ihtiyacın var
  1. How to Fix A Broken Makeup Compact Without Alcohol, How to Fix A Broken Makeup Compact Without Alcohol: adım 1, 1 resimden 1.
    • Plug In the iron and turn the heat to the highest setting.
    • Caution: Be sure to place the iron on a flat, solid surface, away from plastic and other flammable objects.
  2. How to Fix A Broken Makeup Compact Without Alcohol: adım 2, 1 resimden 1.
    • Pour the broken powder into a plastic sandwich bag.
  3. How to Fix A Broken Makeup Compact Without Alcohol: adım 3, 1 resimden 1.
    • Use a spoon to break the powder down into a fine dust.
  4. How to Fix A Broken Makeup Compact Without Alcohol: adım 4, 2 resimden 1. How to Fix A Broken Makeup Compact Without Alcohol: adım 4, 2 resimden 2.
    • Take a knife and carefully remove the metal pan from the compact.
  5. How to Fix A Broken Makeup Compact Without Alcohol: adım 5, 3 resimden 1. How to Fix A Broken Makeup Compact Without Alcohol: adım 5, 3 resimden 2. How to Fix A Broken Makeup Compact Without Alcohol: adım 5, 3 resimden 3.
    • Pour the powder into the metal pan and begin to press the powder down with the spoon.
  6. How to Fix A Broken Makeup Compact Without Alcohol: adım 6, 3 resimden 1. How to Fix A Broken Makeup Compact Without Alcohol: adım 6, 3 resimden 2. How to Fix A Broken Makeup Compact Without Alcohol: adım 6, 3 resimden 3.
    • Turn the heat off on the iron.
    • Caution: Be sure to unplug the iron.
    • Use the heat from the iron to secure the powder in the pan.
    • Press down for 15 seconds at a time.
    • Repeat as needed.
  7. How to Fix A Broken Makeup Compact Without Alcohol: adım 7, 3 resimden 1. How to Fix A Broken Makeup Compact Without Alcohol: adım 7, 3 resimden 2. How to Fix A Broken Makeup Compact Without Alcohol: adım 7, 3 resimden 3.
    • Let cool completely.
    • Place metal pan back into the compact.
    • Now the compact is ready for use.
Bitiş Çizgisi
Cura Mclemore
145 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 415
