Ana içeriğe geç
How to Fix A Crooked Cabinet Door
Neye ihtiyacın var
  1. How to Fix A Crooked Cabinet Door, How to Fix A Crooked Cabinet Door: adım 1, 1 resimden 1.
    • Open the cabinet door, and determine where it is misaligned.
  2. How to Fix A Crooked Cabinet Door: adım 2, 1 resimden 1.
    • Re-attach the hinge into place.
    • Soft-closing multi-adjustable hinges can snap back into their thickness plates which is the part attached to the inside of the cabinet.
    • Avoid placing your fingers near the thickness plate as its force can cause a painful pinch.
  3. How to Fix A Crooked Cabinet Door: adım 3, 1 resimden 1.
    • Hold the hinge firmly against the thickness plate and tighten the screw until the hinge is no longer loose.
    • There are different methods for aligning your cabinet door depending on the screw you tighten and the direction:
    • Side-to-Side Adjustment: To move the door away from the cabinet, screw clockwise. To move the door closer to the cabinet, screw in a counterclockwise motion.
    • Up-Down Adjustment: Screw in a clockwise motion to move the door up. A counterclockwise motion will move the door down.
  4. How to Fix A Crooked Cabinet Door: adım 4, 1 resimden 1.
    • The result of the tightened hinge will look as pictured.
  5. How to Fix A Crooked Cabinet Door: adım 5, 1 resimden 1.
    • Measure along the top and sides of the cabinet with a balance ruler or standard ruler.
    • The result should look as pictured.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Camrynne Paul
121 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 35
Son 30 gün: 158
Her zaman: 9,587
