Ana içeriğe geç
How to Fix A Stripped Screw Hole
Neye ihtiyacın var
  1. How to Fix A Stripped Screw Hole, How to Fix A Stripped Screw Hole: adım 1, 1 resimden 1.
    • Using the toothpick as a reference, measure the depth of the screw-hole and the number of toothpicks needed to fill the screw hole.
  2. How to Fix A Stripped Screw Hole: adım 2, 2 resimden 1. How to Fix A Stripped Screw Hole: adım 2, 2 resimden 2.
    • Next, using the wood glue, cover the area of the toothpick(s) that will fill in the screw hole.
  3. How to Fix A Stripped Screw Hole: adım 3, 2 resimden 1. How to Fix A Stripped Screw Hole: adım 3, 2 resimden 2.
    • Place the toothpicks into the screw hole.
  4. How to Fix A Stripped Screw Hole: adım 4, 1 resimden 1.
    • Now, break off the exposed segment of the toothpick(s).
  5. How to Fix A Stripped Screw Hole: adım 5, 1 resimden 1.
    • Clean off the excess and let the wood glue dry for up to 30 minutes.
    • Recommended wood glue drying time may vary by product.
  6. How to Fix A Stripped Screw Hole: adım 6, 2 resimden 1. How to Fix A Stripped Screw Hole: adım 6, 2 resimden 2.
    • Finally, using the screwdriver, screw the screw into the repaired screw hole.
Sonuç
Your screw should now hold secure.
Isaiah Valdez Mireles
133 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 19
Her zaman: 1,807
