Ana içeriğe geç
How to Fix Broken Powder Make-up
Neye ihtiyacın var
  1. How to Fix Broken Powder Make-up, How to Fix Broken Powder Make-up: adım 1, 3 resimden 1. How to Fix Broken Powder Make-up, How to Fix Broken Powder Make-up: adım 1, 3 resimden 2. How to Fix Broken Powder Make-up, How to Fix Broken Powder Make-up: adım 1, 3 resimden 3.
    • Using the metal butter knife or metal spudger, break up the entire pan of powder into fine pieces.
  2. How to Fix Broken Powder Make-up: adım 2, 3 resimden 1. How to Fix Broken Powder Make-up: adım 2, 3 resimden 2. How to Fix Broken Powder Make-up: adım 2, 3 resimden 3.
    • Pour a small amount of rubbing alcohol into the cap.
    • Slowly add the rubbing alcohol from the cap to the powder and mix it with the knife as you go.
    • Do not use more than two caps worth of rubbing alcohol.
  3. How to Fix Broken Powder Make-up: adım 3, 2 resimden 1. How to Fix Broken Powder Make-up: adım 3, 2 resimden 2.
    • The powder will become creamy with no chunks or bumps. Use the side of the knife to smooth over the top surface.
  4. How to Fix Broken Powder Make-up: adım 4, 1 resimden 1.
    • To completely smooth over the top surface, use a clean finger to push out the edges and even out the surface.
  5. How to Fix Broken Powder Make-up: adım 5, 1 resimden 1.
    • Wait a few hours to let dry before closing the lid. The rubbing alcohol will evaporate, leaving you with a pressed solid ready for re-use.
    • If the powder is not fully dry, let it sit for another hour and continue to check back.
Sonuç
These steps can be used to fix any type of powder makeup (ie. eyeshadows, blush, etc.)
2 farklı kişi bu kılavuzu tamamladı.
Meghan Smith
224 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 30-3, Green Spring 2015 Cal Poly, Team 30-3, Green Spring 2015 üyesi
CPSU-GREEN-S15S30G3
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
It's also good to mash the surface down with something flat like a coin on top of a paper towel, while it's still a little malleable. This way, you get an even, similar texture as when it was new.
Great guide!
Kim Arre - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 35
Her zaman: 1,831
