Ana içeriğe geç
How to Fix Cracked Door Jamb
Neye ihtiyacın var
  1. How to Fix Cracked Door Jamb, How to Fix Cracked Door Jamb: adım 1, 1 resimden 1.
    • Cracked door jamb/frame caused by excessive force on door.
  2. How to Fix Cracked Door Jamb: adım 2, 1 resimden 1.
    • Apply wood filler into the cracks of the door frame.
  3. How to Fix Cracked Door Jamb: adım 3, 2 resimden 1. How to Fix Cracked Door Jamb: adım 3, 2 resimden 2.
    • Attach the clamp onto the cracked door frame.
    • Use a clamp with rubber edges for a sturdier grip and also to prevent damaging the door frame.
  4. How to Fix Cracked Door Jamb: adım 4, 2 resimden 1. How to Fix Cracked Door Jamb: adım 4, 2 resimden 2.
    • Drill a pilot hole into the door frame.
    • Screw a 4-inch screw into the frame through the pilot hole.
  5. How to Fix Cracked Door Jamb: adım 5, 1 resimden 1.
    • Wait for the wood filler to dry.
    • Once dried, scrape off the excess filler with a scraper.
  6. How to Fix Cracked Door Jamb: adım 6, 1 resimden 1.
    • Sand the filled up cracks to get a smooth surface.
  7. How to Fix Cracked Door Jamb: adım 7, 1 resimden 1.
    • Paint and do not touch until dry.
  8. How to Fix Cracked Door Jamb: adım 8, 2 resimden 1. How to Fix Cracked Door Jamb: adım 8, 2 resimden 2.
    • Repaired door frame/ door jamb.
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
Anisha Karaumbiah
265 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 38
Son 30 gün: 179
Her zaman: 44,939
