Ana içeriğe geç
How to Fix Cracked Glassware with Food Safe Resin
Neye ihtiyacın var
  1. How to Fix Cracked Glassware with Food Safe Resin, How to Fix Cracked Glassware with Food Safe Resin: adım 1, 1 resimden 1.
    • Lay a garbage bag out on your workstation and put on disposable gloves.
    • Using separate cups, measure the resin and hardener to an exact 1:1 ratio.
    • Always wear gloves and ensure your work area is well-ventilated while working with resin. You may also want to wear safety glasses to protect your eyes.
  2. How to Fix Cracked Glassware with Food Safe Resin: adım 2, 2 resimden 1. How to Fix Cracked Glassware with Food Safe Resin: adım 2, 2 resimden 2.
    • Add the resin and hardener to a container or bowl to mix the solution.
    • Scrape the sides of the measuring cups to ensure that both liquids are fully incorporated.
  3. How to Fix Cracked Glassware with Food Safe Resin: adım 3, 1 resimden 1.
    • Use the mixing stick to stir the resin and hardener for at least three minutes.
    • Scrape the sides and bottom while mixing.
  4. How to Fix Cracked Glassware with Food Safe Resin: adım 4, 2 resimden 1. How to Fix Cracked Glassware with Food Safe Resin: adım 4, 2 resimden 2.
    • Dip one end of the Q-Tip into the resin mixture. Submerging is not necessary; ensure the tip is coated enough to cover the surface of the crack.
    • Apply the resin mixture to the affected area(s), covering the crack completely. Cover both the inside and outside of the crack if necessary.
    • Be careful of loose shards of glass.
  5. How to Fix Cracked Glassware with Food Safe Resin: adım 5, 1 resimden 1.
    • Allow the resin to cure for at least eight hours.
  6. How to Fix Cracked Glassware with Food Safe Resin: adım 6, 2 resimden 1. How to Fix Cracked Glassware with Food Safe Resin: adım 6, 2 resimden 2.
    • Place the Q-tip and leftover resin into a disposable, sealable plastic bag.
    • Allow it to cure for 8+ hours before disposing.
    • Do NOT pour resin down the drain or into the sink.
    • Flip the measuring and mixing cups over the trash bag to remove any excess resin or hardener.
  7. How to Fix Cracked Glassware with Food Safe Resin: adım 7, 2 resimden 1. How to Fix Cracked Glassware with Food Safe Resin: adım 7, 2 resimden 2.
    • When the resin has finished curing, use an alcohol wipe to remove any excess from the surface of your glass item.
    • If the resin is too hard, use a craft blade to gently scrape off the excess.
    • Exercise caution when working with blades.
  8. How to Fix Cracked Glassware with Food Safe Resin: adım 8, 2 resimden 1. How to Fix Cracked Glassware with Food Safe Resin: adım 8, 2 resimden 2.
    • Pour warm water to ensure that the glassware is heat-safe and that the cracks are completely sealed.
    • Wash the glassware gently and thoroughly to remove any excess resin applied on the inside.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Hana
181 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
After applying resin, can I heat the item in open flame source ?
Jaggermeister Asti - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 31
Son 30 gün: 159
Her zaman: 1,231
