Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This is a guide to fix the E-Paper tearing in Pebble 301BL devices.
*this will void the warranty for the device*
Neye ihtiyacın var
Bu adımda kullanılan alet:T5 Torx Screwdriver$5.49
Using a T5 Torx screwdriver, remove the 4 screws on the back.
Locate the video connector near the bottom, right next to the device that vibrates when you get a notification.
What worked for me is taking a little toilet tissue or paper towel and placing it over the video connector.
Once you have confirmed that the paper will apply the necessary pressure, you can then put the screws back in.
If the case doesn't close properly, you will need to open the device back up and remove a tiny bit of the paper until it does close, that way it will retain its water resistance.
40 farklı kişi bu kılavuzu tamamladı.
9 Yorum
This guide sadly only works for the revised model. The kickstarter edition had no screws in the back and have to be pried open from the screen, making the repair next to impossible without badly damaging de case or/and the screen.
Would something like the iopener work for that? Have had just about every model bar the original ks edition so im not sure myself.
It is possible with heat and a ton of patients. Took a buddy of mine a whole afternoon to open it. Once he had the connector reseated, he actually used a of some sort to hold it in place instead so he wouldn't have to have the whole Pebble stuffed. Then he used the same putty/glue to help seal the watch shut. I'll see if he'll tell me what it was.
"To reassemble your device, follow these instructions in reverse order." .... so take it apart again and remove the tissue?
I see you are trying to be funny.
In case you were serious: no do not remove the tissue.
