Ana içeriğe geç
How to Fix Joy-Con Drift Without Disassembly
Neye ihtiyacın var
  1. How to Fix Joy-Con Drift Without Disassembly, How to Fix Joy-Con Drift Without Disassembly: adım 1, 2 resimden 1. How to Fix Joy-Con Drift Without Disassembly, How to Fix Joy-Con Drift Without Disassembly: adım 1, 2 resimden 2.
    • Press and hold the black round button on the back of the Joy-Con, then slide it forward to remove.
  2. How to Fix Joy-Con Drift Without Disassembly: adım 2, 2 resimden 1. How to Fix Joy-Con Drift Without Disassembly: adım 2, 2 resimden 2.
    • Open the 404B contact cleaner and insert the tube into the nozzle.
  3. How to Fix Joy-Con Drift Without Disassembly: adım 3, 1 resimden 1.
    • Push the Joy Stick to the side and hold.
  4. How to Fix Joy-Con Drift Without Disassembly: adım 4, 2 resimden 1. How to Fix Joy-Con Drift Without Disassembly: adım 4, 2 resimden 2.
    • Use tweezers to lift the rubber ring under the Joy Stick, and hold.
  5. How to Fix Joy-Con Drift Without Disassembly: adım 5, 2 resimden 1. How to Fix Joy-Con Drift Without Disassembly: adım 5, 2 resimden 2.
    • Aim the contact cleaner's nozzle at the gap and spray 404B contact cleaner once or twice.
  6. How to Fix Joy-Con Drift Without Disassembly: adım 6, 3 resimden 1. How to Fix Joy-Con Drift Without Disassembly: adım 6, 3 resimden 2. How to Fix Joy-Con Drift Without Disassembly: adım 6, 3 resimden 3.
    • Rotate the Joy Stick for 30 seconds to allow full penetration of the liquid inside.
  7. How to Fix Joy-Con Drift Without Disassembly: adım 7, 1 resimden 1.
    • Wait 10 minutes for the liquid to dry completely.
  8. How to Fix Joy-Con Drift Without Disassembly: adım 8, 3 resimden 1. How to Fix Joy-Con Drift Without Disassembly: adım 8, 3 resimden 2. How to Fix Joy-Con Drift Without Disassembly: adım 8, 3 resimden 3.
    • Insert the Joy-Con back into the Switch to test the Joy-Con.
    • Navigate to System Settings > Controllers and Sensors > Calibrate Control Sticks.
    • Follow the on-screen prompts on your Switch.
Sonuç
Enjoy your Joy-Con being able to work properly again!
19 farklı kişi bu kılavuzu tamamladı.
Weijie Chen
706 İtibar
1 Kılavuz yazıldı
Ekip
2 Yorum
Muchas gracias.
AlmudenaPita - Yanıt
Process says it requires compressed air then goes on to use contact cleaner instead.
Mike Burr - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 49
Son 7 gün: 327
Son 30 gün: 1,382
Her zaman: 36,132
