Ana içeriğe geç
How to Fix Keurig K75 Platinum Brewing System Water Pump Leak
Neye ihtiyacın var
  1. How to Fix Keurig K75 Platinum Brewing System Water Pump Leak, Baseplate: adım 1, 2 resimden 1. How to Fix Keurig K75 Platinum Brewing System Water Pump Leak, Baseplate: adım 1, 2 resimden 2.
    • Before beginning the repair, turn off the brewer and disconnect it from any power source.
    • Move the brewer so that the metal baseplate is easily accessible.
    • Remove the five silver 4 mm Phillips #2 screws from the baseplate.
  2. How to Fix Keurig K75 Platinum Brewing System Water Pump Leak: adım 2, 2 resimden 1. How to Fix Keurig K75 Platinum Brewing System Water Pump Leak: adım 2, 2 resimden 2.
    • Using a spudger, gently pry the metal baseplate from the brewer.
    • Gently set down the baseplate.
  3. How to Fix Keurig K75 Platinum Brewing System Water Pump Leak, How to Fix Keurig K75 Platinum Brewing System Water Pump Leak: adım 3, 2 resimden 1. How to Fix Keurig K75 Platinum Brewing System Water Pump Leak, How to Fix Keurig K75 Platinum Brewing System Water Pump Leak: adım 3, 2 resimden 2.
    • Remove the two silver 4mm Phillips #2 screws that hold the water pump in place.
  4. How to Fix Keurig K75 Platinum Brewing System Water Pump Leak: adım 4, 1 resimden 1.
    • Realign the rubber gasket of the water pump to create a tight fit.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kristen Temnyk
515 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-2, Maness Winter 2013 Cal Poly, Team 20-2, Maness Winter 2013 üyesi
CPSU-MANESS-W13S20G2
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 12
Son 30 gün: 19
Her zaman: 21,716
