Giriş
If your PS4 DualShock Controller is having the drifting joystick problem which is common—automatically moving without touch, becomes stuck once touched—use this guide to repair the issue without any soldering, which many people may not have experience in.
The controller will have to be dismantled completely so that the left joystick can be cleaned and worked on. This simple repair with minimal knowledge is an easy fix. P.S. the gloves are not required to wear when the controller is being worked on.
Neye ihtiyacın var
Remove the four 6.0 mm screws on the back shell of the PS4 controller using the Phillips #00 screwdriver.
61 farklı kişi bu kılavuzu tamamladı.
9 Yorum
Yes! Both sticks seems to be identical. Did my right one and it fixed the drift.
i fix my brothers ds4 with your tutorial. Thank you very much.
Thank you so much for this amazingly well made guide. I just fixed my PS4 controller and it surprised me how well it works, absolutely no drift whatsoever. I should note that i’ve done the same steps on the right stick as it’s the one broken for me.
I just followed the guide and the drift problem is gone! A really throughout guide with all the details and warnings. Thank you for this.
