Ana içeriğe geç
How to Fix Oculus 2 Quest Controller Drift Without Disassembly
Neye ihtiyacın var
  1. How to Fix Oculus 2 Quest Controller Drift Without Disassembly, How to Fix Oculus 2 Quest Controller Drift Without Disassembly: adım 1, 1 resimden 1.
    • Remove the battery cover from the controller.
    • Remove the battery.
  2. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: adım 2, 2 resimden 1. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: adım 2, 2 resimden 2.
    • Flip the straw up on the WD-40 for a pinpoint stream.
    • Make sure to use WD-40 specialist contact cleaner as opposed to traditional WD-40 which may damage your controller.
  3. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: adım 3, 3 resimden 1. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: adım 3, 3 resimden 2. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: adım 3, 3 resimden 3.
    • Shake the can well for 20 to 30 seconds before each spray.
  4. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: adım 4, 1 resimden 1.
    • Hold the joystick down in the opposite direction of the drift.
  5. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: adım 5, 1 resimden 1.
    • Spray a small amount of the product into the joystick
    • It's important to use WD-40 specialist contact cleaner instead of the regular WD-40. It will break the controller if you use the wrong can.
  6. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: adım 6, 3 resimden 1. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: adım 6, 3 resimden 2. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: adım 6, 3 resimden 3.
    • Wiggle the joystick around in circles to spread the residue.
    • Click the joystick down a couple of times.
  7. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: adım 7, 1 resimden 1.
    • Wait for the the residue to dry for 3 minutes.
    • Replace the battery.
Bitiş Çizgisi
12 farklı kişi bu kılavuzu tamamladı.
Adrian Sanchez
437 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 2-89, Briggs Fall 2022 CSU Los Angeles, Team 2-89, Briggs Fall 2022 üyesi
CSULA-BRIGGS-F22S2G89
1 Üye
6 adet Kılavuz yazıldı
8Kılavuz Yorumları
In the article you warn the user:
"It's important to use WD-40 specialist contact cleaner instead of the regular WD-40. It will break the controller if you use the wrong can."
Are you referring to the "WD-40 Specialist ELECTRICAL Contact Cleaner" or just the "WD-40 Specialist Contact Cleaner?"
They're apparently two different products, with the former coming in a black/dark gray can (at twice the price) and the latter coming in the dark blue can that WD-40 has traditionally come in, and I don't want to pick up the wrong product for this.
Thanks for your time!
WafflesASAP - Yanıt
I feel that it being an electronic that it will use the electronic contact cleaner.
Francisco 1234 Cruz YT -
https://www.wd40.com/products/contact-cl... - The page indicates that they changed the appearance of the can, not the formulation. The two products you describe are the same one.
jon42 -
B and Y buttons no longer work after I used this method and fixed the stick drift.
Morgen Hoshi - Yanıt
Did not really work, didn’t even break the controller either, I should probably try again or something, also when I used the normal WD-40 it did not break anything but I am still suggesting to use the WD-40 specialist ELECTRICAL contact cleaner, have a nice day mate
ICameHereForWisdom - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 102
Son 30 gün: 530
Her zaman: 28,582
