Ana içeriğe geç
How to Fix PS4 Controller Joystick Drift Without Disassembling
  1. How to Fix PS4 Controller Joystick Drift Without Disassembling, How to Fix PS4 Controller Joystick Drift Without Disassembling: adım 1, 1 resimden 1.
    • Before you begin, make sure your PlayStation 4 controller is not connected to the console or any cables.
  2. How to Fix PS4 Controller Joystick Drift Without Disassembling: adım 2, 1 resimden 1.
    • Dip a cotton swab in rubbing alcohol.
  3. How to Fix PS4 Controller Joystick Drift Without Disassembling: adım 3, 1 resimden 1.
    • Use the cotton swab with rubbing alcohol to clean the joystick and its base of any debris or dust.
  4. How to Fix PS4 Controller Joystick Drift Without Disassembling: adım 4, 1 resimden 1.
    • Let the controller dry for about 10 to 15 minutes.
  5. How to Fix PS4 Controller Joystick Drift Without Disassembling: adım 5, 1 resimden 1.
    • Spray compressed air around the base of the joystick to further remove any dust or debris.
    • Make sure the can of compressed air is level to avoid adding moisture to the joystick.
  6. How to Fix PS4 Controller Joystick Drift Without Disassembling: adım 6, 1 resimden 1.
    • Press forward on the thumbsticks for 30 seconds.
  7. How to Fix PS4 Controller Joystick Drift Without Disassembling: adım 7, 1 resimden 1.
    • Press down on the joystick and move it 360 degrees clockwise and counter-clockwise for 30 seconds.
  8. How to Fix PS4 Controller Joystick Drift Without Disassembling: adım 8, 1 resimden 1.
    • Turn on the console to begin rebooting your controller.
  9. How to Fix PS4 Controller Joystick Drift Without Disassembling: adım 9, 1 resimden 1.
    • Disconnect your controller once more from the console.
  10. How to Fix PS4 Controller Joystick Drift Without Disassembling: adım 10, 1 resimden 1.
    • Press the tip of a small paper clip into the reset button on the back of the controller and hold for ten seconds.
    • After ten seconds, your controller will reboot.
Bitiş Çizgisi
10 farklı kişi bu kılavuzu tamamladı.
Murtaza Lutfi
429 İtibar
1 Kılavuz yazıldı
2 Comments
It's still doing the same thing and I bought this fresh out of the box, now the PS4 is used and it comes on just fine.
What should I do I'm confused
Ray cromartie - Yanıt
How can I get my controller to work
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 125
Son 7 gün: 827
Son 30 gün: 4,150
Her zaman: 28,257
