Ana içeriğe geç
How to Fix Paint Chips or Large Scratches on a Car
Neye ihtiyacın var
    1. How to Fix Paint Chips or Large Scratches on a Car, How to Fix Paint Chips or Large Scratches on a Car: adım 1, 1 resimden 1.
      • Wipe down the area of the paint chip or scratch with a damp papertowel.
      FixBot'a Sor
      Yorum Ekle
    2. How to Fix Paint Chips or Large Scratches on a Car: adım 2, 1 resimden 1.
      • Place tape around anything you do not want to get paint on.
      • e.g. windows, taillights/headlights, metal decals, license plates, etc.
      FixBot'a Sor
      Yorum Ekle
    3. How to Fix Paint Chips or Large Scratches on a Car: adım 3, 1 resimden 1.
      • Sand down the paint chip or scratch, including the immediate surrounding area.
      • Start with a coarse grain.
      • Then move to a fine grain to remove any sharp edges.
      • Don't sand too far out around the area. The goal of using sandpaper is to reduce any edges to prevent rusting underneath the paint, and to create a surface that the primer will stick to.
      FixBot'a Sor
      Yorum Ekle
    4. How to Fix Paint Chips or Large Scratches on a Car: adım 4, 1 resimden 1.
      • Wipe down the area with a dry papertowel to remove debris.
      FixBot'a Sor
      Yorum Ekle
    5. How to Fix Paint Chips or Large Scratches on a Car: adım 5, 1 resimden 1.
      • Spray the primer all over the area that was sanded. Use small strokes and spray the primer around the area.
      • Wait 10 minutes or until it feels dry when touched.
      • Add another layer or two if you can still see the edge of the paint chip or scratch.
      • The goal is to fill in the scratch or chip with primer to prevent rust.
      • Let it dry for 15-20 minutes before moving to the next step.
      FixBot'a Sor
      Yorum Ekle
    6. How to Fix Paint Chips or Large Scratches on a Car: adım 6, 1 resimden 1.
      • Spray on a coat of colored paint. Use small strokes and spray the paint around the area.
      • Spraying at least 6 inches (no more than 10 inches) away from the surface will prevent paint from dripping.
      • Paint drips can be removed by gently dabbing them with a dry paper towel.
      • Allow to dry.
      • Drying time takes at least 10 minutes per coat of paint.
      • Continue adding coats and drying in between until primer cannot be seen through the paint.
      FixBot'a Sor
      Yorum Ekle
    7. How to Fix Paint Chips or Large Scratches on a Car: adım 7, 1 resimden 1.
      • Spray on the clear protective coat. Use small strokes and spray the clear coat around the area.
      • Allow to dry for 10 minutes or until the area feels dry when touched.
      • Add at least 3 more coats, allowing each coat to dry in between.
      • The clear coat helps prevent rust and adds a refective texture that helps the paint job blend in.
      FixBot'a Sor
      Yorum Ekle
      • Remove masking tape from the car when finished.
      • If you accidentally got paint on your windows, it will come off if you scratch it with a flat razor.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
6 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
نحياتي لكل مجتهد ومساهم هنا
Abdullah Shaweil - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 77
Son 30 gün: 368
Her zaman: 17,483
