Ana içeriğe geç
How to Fix Plastic Chair Cracks
Neye ihtiyacın var
  1. How to Fix Plastic Chair Cracks, How to Fix Plastic Chair Cracks: adım 1, 2 resimden 1. How to Fix Plastic Chair Cracks, How to Fix Plastic Chair Cracks: adım 1, 2 resimden 2.
    • Lay the broken chair such that the crack is parallel to the floor.
    FixBot'a Sor
    Yorum Ekle
  2. How to Fix Plastic Chair Cracks: adım 2, 2 resimden 1. How to Fix Plastic Chair Cracks: adım 2, 2 resimden 2.
    • Wear gloves to minimize chemical contact on skin.
    • Dampen a rag with isopropyl alcohol.
    FixBot'a Sor
    Yorum Ekle
  3. How to Fix Plastic Chair Cracks: adım 3, 2 resimden 1. How to Fix Plastic Chair Cracks: adım 3, 2 resimden 2.
    • Clean the surface of the crack with the dampened rag to remove all dust and debris.
    • Repeat on all sides of the crack (edges and backside).
    FixBot'a Sor
    Yorum Ekle
  4. How to Fix Plastic Chair Cracks: adım 4, 3 resimden 1. How to Fix Plastic Chair Cracks: adım 4, 3 resimden 2. How to Fix Plastic Chair Cracks: adım 4, 3 resimden 3.
    • Apply glue between the crack.
    • Then apply glue across the surface of the crack.
    FixBot'a Sor
    Yorum Ekle
  5. How to Fix Plastic Chair Cracks: adım 5, 1 resimden 1.
    • Hold the two glued pieces together for 30 seconds to allow the glue to bind to the chair.
    • Do not let the glue dry completely. The wet glue will need to bind with baking soda in the next step.
    FixBot'a Sor
    Yorum Ekle
  6. How to Fix Plastic Chair Cracks: adım 6, 3 resimden 1. How to Fix Plastic Chair Cracks: adım 6, 3 resimden 2. How to Fix Plastic Chair Cracks: adım 6, 3 resimden 3.
    • Pour baking soda over the crack until the glue is completely covered under a layer of baking soda.
    FixBot'a Sor
    Yorum Ekle
  7. How to Fix Plastic Chair Cracks: adım 7, 2 resimden 1. How to Fix Plastic Chair Cracks: adım 7, 2 resimden 2.
    • Use your finger to distribute the baking soda in order to cover all parts of the crack.
    FixBot'a Sor
    Yorum Ekle
  8. How to Fix Plastic Chair Cracks: adım 8, 3 resimden 1. How to Fix Plastic Chair Cracks: adım 8, 3 resimden 2. How to Fix Plastic Chair Cracks: adım 8, 3 resimden 3.
    • Allow the baking soda to seal onto the super glue over the crack and wait for the mixture to dry.
    • After ten minutes, brush away some of the un-glued baking soda to check if the glue is solid.
    FixBot'a Sor
    Yorum Ekle
  9. How to Fix Plastic Chair Cracks: adım 9, 2 resimden 1. How to Fix Plastic Chair Cracks: adım 9, 2 resimden 2.
    • Flip the chair over.
    • Repeat the procedure on the backside of the crack starting from step 4 and ending with step 8.
    • Avoid reapplying glue in between crack, since it has already been sealed.
    FixBot'a Sor
    Yorum Ekle
  10. How to Fix Plastic Chair Cracks: adım 10, 2 resimden 1. How to Fix Plastic Chair Cracks: adım 10, 2 resimden 2.
    • Remove excess baking soda from both the front and back side of the crack.
    • Use water or isopropyl alcohol to remove fine grains around the repair site.
    FixBot'a Sor
    Yorum Ekle
  11. How to Fix Plastic Chair Cracks: adım 11, 1 resimden 1.
    • Sand off any excess layers of glue on both the front and backside of the chair using coarse sandpaper.
    • This step is optional and simply helps to return the chair to its original look.
    • It may take a while to rid the chair of all texture.
    FixBot'a Sor
    Yorum Ekle
  12. How to Fix Plastic Chair Cracks: adım 12, 1 resimden 1.
    • The crack has been repaired!
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
20 farklı kişi bu kılavuzu tamamladı.
Sumeet Dhillon
565 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S2-G7, Andersen Winter 2020 UC Davis, Team S2-G7, Andersen Winter 2020 üyesi
UCD-ANDERSEN-W20S2G7
3 Üyeler
6 adet Kılavuz yazıldı
4Kılavuz Yorumları
Do you push the baking soda down into the glue (or into the crack), or just spread evenly on the surface?
Dr John Christensen - Yanıt Paylaş
What glue did you use?
Raffaele Bianchi - Yanıt Paylaş
Lem apa yang digunakan (nama lem)
Iwan Toro - Yanıt Paylaş
There is also duct tape.
Theo Grefalda - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 166
Son 30 gün: 852
Her zaman: 63,409
