Ana içeriğe geç
How to Fix Sagging IKEA Lack Shelves
Neye ihtiyacın var
  1. How to Fix Sagging IKEA Lack Shelves, How to Fix Sagging IKEA Lack Shelves: adım 1, 3 resimden 1. How to Fix Sagging IKEA Lack Shelves, How to Fix Sagging IKEA Lack Shelves: adım 1, 3 resimden 2. How to Fix Sagging IKEA Lack Shelves, How to Fix Sagging IKEA Lack Shelves: adım 1, 3 resimden 3.
    • Hold the shelf on both sides and push it upwards. Slowly pull the shelf out to expose the anchored screws.
  2. How to Fix Sagging IKEA Lack Shelves: adım 2, 3 resimden 1. How to Fix Sagging IKEA Lack Shelves: adım 2, 3 resimden 2. How to Fix Sagging IKEA Lack Shelves: adım 2, 3 resimden 3.
    • Pull out the loose screws and plugs to expose the holes in the wall.
    • Drill into these holes using a cordless power drill machine to even out the edge of the holes and to make sure the hole is deep enough for the new screws and plugs.
  3. How to Fix Sagging IKEA Lack Shelves: adım 3, 3 resimden 1. How to Fix Sagging IKEA Lack Shelves: adım 3, 3 resimden 2. How to Fix Sagging IKEA Lack Shelves: adım 3, 3 resimden 3.
    • Apply the drywall filler into the holes and also over the holes to cover it.
    • This filler becomes hard as concrete when it dries, It will hold the screw firmly in place.
  4. How to Fix Sagging IKEA Lack Shelves: adım 4, 3 resimden 1. How to Fix Sagging IKEA Lack Shelves: adım 4, 3 resimden 2. How to Fix Sagging IKEA Lack Shelves: adım 4, 3 resimden 3.
    • Smooth out the drywall filler using a taping knife.
    • Applying poly filler over the holes and smoothing it out will create an even texture and hide the edges of each hole.
  5. How to Fix Sagging IKEA Lack Shelves: adım 5, 3 resimden 1. How to Fix Sagging IKEA Lack Shelves: adım 5, 3 resimden 2. How to Fix Sagging IKEA Lack Shelves: adım 5, 3 resimden 3.
    • Insert a Phillips #10 screw and plug into each hole carefully.
    • Make sure the wall plug is pushed inside entirely, only exposing the edges.
  6. How to Fix Sagging IKEA Lack Shelves: adım 6, 3 resimden 1. How to Fix Sagging IKEA Lack Shelves: adım 6, 3 resimden 2. How to Fix Sagging IKEA Lack Shelves: adım 6, 3 resimden 3.
    • When the wall plug and screw is pushed into the hole, the smoothed out drywall filler will become messy around the edges.
    • Using the taping knife, carefully smooth out the drywall filler around the screws.
  7. How to Fix Sagging IKEA Lack Shelves: adım 7, 3 resimden 1. How to Fix Sagging IKEA Lack Shelves: adım 7, 3 resimden 2. How to Fix Sagging IKEA Lack Shelves: adım 7, 3 resimden 3.
    • Now proceed to drive the screw into the wall plug and secure it in place.
    • Drive the screw-in until 1-1.5inch space is left between the wall and the screw head.
  8. How to Fix Sagging IKEA Lack Shelves: adım 8, 3 resimden 1. How to Fix Sagging IKEA Lack Shelves: adım 8, 3 resimden 2. How to Fix Sagging IKEA Lack Shelves: adım 8, 3 resimden 3.
    • Apply more drywall filler over the edges of the wall plug to hide it.
    • Using the taping knife, smooth out the drywall filler.
    • This step may look redundant but it is necessary to secure the screw and plug firmly.
  9. How to Fix Sagging IKEA Lack Shelves: adım 9, 3 resimden 1. How to Fix Sagging IKEA Lack Shelves: adım 9, 3 resimden 2. How to Fix Sagging IKEA Lack Shelves: adım 9, 3 resimden 3.
    • After the drywall filler hardens. it is time to insert the shelf in place.
    • Insert the round side of the hook into each screw. Then push the shelf downwards until it is level to secure it in place.
Sonuç
The shelf is now fixed!
3 farklı kişi bu kılavuzu tamamladı.
Sanjana Salam
223 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 37
Son 7 gün: 247
Son 30 gün: 1,336
Her zaman: 102,958
