Ana içeriğe geç
Giriş
This guide will allow you to quickly de-stick house windows in an efficient, and long lasting way with WD-40 Specialist Silicone Lubricant.
Parçalar
Hiçbir parça belirtilmedi.
  1. Unlock the windows' sash lock.
    • Unlock the windows' sash lock.
  2. Slide a single window pane in its' opposite direction.
    • Slide a single window pane in its' opposite direction.
  3. Apply the silicone spray where the window and channel connect if the window is stuck.
    • Apply the silicone spray where the window and channel connect if the window is stuck.
  4. iPhone Pil Tamir Setleri
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  5. Apply a thin coating of the silicone spray onto the windows' channels. Apply a thin coating of the silicone spray onto the windows' channels.
    • Apply a thin coating of the silicone spray onto the windows' channels.
  6. Slide the window up and down along the channel until the silicone spray is evenly distributed. Slide the window up and down along the channel until the silicone spray is evenly distributed.
    • Slide the window up and down along the channel until the silicone spray is evenly distributed.
  7. Repeat steps 2 - 5 with the opposite window pane. Repeat steps 2 - 5 with the opposite window pane.
    • Repeat steps 2 - 5 with the opposite window pane.
  8. Apply more silicone spray as needed. Apply more silicone spray as needed.
    • Apply more silicone spray as needed.
Bitiş Çizgisi
Anna Handza
145 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 2
Her zaman: 41
