Ana içeriğe geç
How to Fix Stripped Screw Holes from Cabinet Hinges
Neye ihtiyacın var
  1. How to Fix Stripped Screw Holes from Cabinet Hinges, How to Fix Stripped Screw Holes from Cabinet Hinges: adım 1, 3 resimden 1. How to Fix Stripped Screw Holes from Cabinet Hinges, How to Fix Stripped Screw Holes from Cabinet Hinges: adım 1, 3 resimden 2. How to Fix Stripped Screw Holes from Cabinet Hinges, How to Fix Stripped Screw Holes from Cabinet Hinges: adım 1, 3 resimden 3.
    • Use a screwdriver to remove the screws from the stripped holes.
  2. How to Fix Stripped Screw Holes from Cabinet Hinges: adım 2, 1 resimden 1.
    • Take a screw from the cabinet hinge and use it to determine the appropriate size of screw anchor.
  3. How to Fix Stripped Screw Holes from Cabinet Hinges: adım 3, 2 resimden 1. How to Fix Stripped Screw Holes from Cabinet Hinges: adım 3, 2 resimden 2.
    • Clear the screw holes of any debris.
  4. How to Fix Stripped Screw Holes from Cabinet Hinges: adım 4, 2 resimden 1. How to Fix Stripped Screw Holes from Cabinet Hinges: adım 4, 2 resimden 2.
    • Place the screw anchors within each of the stripped screw holes.
  5. How to Fix Stripped Screw Holes from Cabinet Hinges: adım 5, 2 resimden 1. How to Fix Stripped Screw Holes from Cabinet Hinges: adım 5, 2 resimden 2.
    • Secure the screw anchors within the hole by lightly tapping on them with a hammer.
    • Too much force can damage the anchor.
  6. How to Fix Stripped Screw Holes from Cabinet Hinges: adım 6, 2 resimden 1. How to Fix Stripped Screw Holes from Cabinet Hinges: adım 6, 2 resimden 2.
    • Once the screw anchors are secured in place, align the cabinet hinges with the anchor holes.
    • Top of the anchor must fit tightly in the stripped hole.
  7. How to Fix Stripped Screw Holes from Cabinet Hinges: adım 7, 3 resimden 1. How to Fix Stripped Screw Holes from Cabinet Hinges: adım 7, 3 resimden 2. How to Fix Stripped Screw Holes from Cabinet Hinges: adım 7, 3 resimden 3.
    • Use a screwdriver and spin clockwise to screw the nail in place.
  8. How to Fix Stripped Screw Holes from Cabinet Hinges: adım 8, 1 resimden 1.
    • The screws are now secured, and the cabinet will no longer wobble.
Sonuç
Well done!
3 farklı kişi bu kılavuzu tamamladı.
Richmond La
247 İtibar
1 Kılavuz yazıldı
Ekip
2Kılavuz Yorumları
Boutje moertje door de wand is ook stevig
Aad Petersen - Yanıt
Wat also de gat te groot is. Moet je dan niet eerst gat vullen. Maar wat is handig, lijm of wax?
Nas sai - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 86
Son 30 gün: 457
Her zaman: 35,942
