Ana içeriğe geç
How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard
Neye ihtiyacın var
  1. How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard, Mem-chanical Key Switches: adım 1, 1 resimden 1.
    • Unplug the keyboard before beginning this guide.
    • Disconnecting the keyboard from its power supply will decrease the chance of any electrical discharge.
  2. How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard: adım 2, 2 resimden 1. How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard: adım 2, 2 resimden 2.
    • Remove all keycaps that feel stuck or sticky with a keycap puller or similar tool.
    • Some keycaps may feel tough to pull off. Ensure that even force is applied to all contact points with the keycap and keycap puller.
  3. How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard: adım 3, 1 resimden 1.
    • Soak a cotton swab in alcohol.
    • Potential for device damage: Ensure that the cotton swab is not too damp. Excess alcohol may reach deep inside the keyboard housing, potentially damaging electrical components.
  4. How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard: adım 4, 1 resimden 1.
    • Clean the sides of the switch housing using the cotton swab.
    • Typically the surfaces of the switch stem, that come in contact with the housing, build up dirt that leads to keys feeling stuck or sticky. Pay close attention to these areas.
  5. How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard: adım 5, 3 resimden 1. How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard: adım 5, 3 resimden 2. How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard: adım 5, 3 resimden 3.
    • Reinstall the keycap. Line up the bottom of the keycap with the switch's housing. Verify a snug fit has been made.
  6. How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard: adım 6, 1 resimden 1.
    • Test the switch frequently by pressing down repeatedly with your finger.
    • This will help you gauge how well the alcohol is cleaning dirt build up.
  7. How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard: adım 7, 1 resimden 1.
    • Repeat until all switches have been cleaned and are feeling more responsive when pressed.
    • Between cleanings, ensure that the cotton swab remains moist but not too damp.
    • Potential for device damage: If a switch does not feel more responsive after two or three cleanings, do not continue to clean. Continued cleaning may result in excess alcohol reaching deep into the housing of the keyboard. This could lead to damaging electrical components.
  8. How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard: adım 8, 1 resimden 1.
    • Return all keycaps to their appropriate place on the keyboard. Pay close attention to the orientation of the letter of the keycap. Ensure that all keycaps are returned facing the correct direction.
    • Do not try to force a keycap back on to the switch. Ensure that the back of the keycap is properly aligned with the stem of the switch.
Sonuç
Rosewell’s offering of “mem-chanical” keyboard switches are unique but not immune to dirt/grime build-up. You will find that cleaning the housing of theses switches will typically alleviate any sticky, or stuck, feeling keys.
Christopher Gonzales
157 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 23
Her zaman: 3,710
