Ana içeriğe geç
How to Fix Subwoofer Amplifiers
Neye ihtiyacın var
  1. How to Fix Subwoofer Amplifiers, How to Fix Subwoofer Amplifiers: adım 1, 1 resimden 1.
    • Disconnect the black (negative) cable from the battery to disable the electrical connection.
    • Always disconnect the negative cable before the positive cable.
    • Disconnect the red (positive) cable from the battery to disable the electrical connection.
  2. How to Fix Subwoofer Amplifiers: adım 2, 1 resimden 1.
    • Pull the fuses out and make sure that they were not blown.
  3. How to Fix Subwoofer Amplifiers: adım 3, 1 resimden 1.
    • Undo and remove all wires from the amplifier.
    • This should include the battery wire, ground wire, speaker wires, remote wire from the radio, and sound wires that also come from radio.
    • Remove and check the fuse from the amp to make sure it is not a blown fuse.
  4. How to Fix Subwoofer Amplifiers: adım 4, 1 resimden 1.
    • Strip the wires so they can have a better connection.
    • Twist the exposed copper wiring to make it easier to connect to the amplifier.
  5. How to Fix Subwoofer Amplifiers: adım 5, 1 resimden 1.
    • Replace the wires in their designated slots.
    • Tighten the clamps all the way down.
    • Wiggle and tug on the wires to make sure they are secured nice and tight.
  6. How to Fix Subwoofer Amplifiers: adım 6, 1 resimden 1.
    • Replace the battery wires.
    • The red wire should go to the positive side, and the black wire should go to the negative side.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Luke Turner
154 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 58
Her zaman: 2,039
