Ana içeriğe geç
How to Fix Thread Tension on a Juki DDL-8700
Neye ihtiyacın var
  1. How to Fix Thread Tension on a Juki DDL-8700, How to Fix Thread Tension on a Juki DDL-8700: adım 1, 3 resimden 1. How to Fix Thread Tension on a Juki DDL-8700, How to Fix Thread Tension on a Juki DDL-8700: adım 1, 3 resimden 2. How to Fix Thread Tension on a Juki DDL-8700, How to Fix Thread Tension on a Juki DDL-8700: adım 1, 3 resimden 3.
    • Thread the machine.
    • Insert the bobbin case.
  2. How to Fix Thread Tension on a Juki DDL-8700: adım 2, 3 resimden 1. How to Fix Thread Tension on a Juki DDL-8700: adım 2, 3 resimden 2. How to Fix Thread Tension on a Juki DDL-8700: adım 2, 3 resimden 3.
    • Sew a straight line on scrap fabric to test thread tension.
    • Be cautious when placing your fingers near the needle when working with the machine turned on.
  3. How to Fix Thread Tension on a Juki DDL-8700: adım 3, 2 resimden 1. How to Fix Thread Tension on a Juki DDL-8700: adım 3, 2 resimden 2.
    • Check the fabric for loose thread tension.
    • Look out for loops of thread on the top and bottom of the fabric.
    • The bobbin case tension is too loose if loops are on the top of the fabric.
    • The upper thread tension is too loose if the loops are on the bottom of the fabric.
  4. How to Fix Thread Tension on a Juki DDL-8700: adım 4, 2 resimden 1. How to Fix Thread Tension on a Juki DDL-8700: adım 4, 2 resimden 2.
    • Take out the bobbin case.
  5. How to Fix Thread Tension on a Juki DDL-8700: adım 5, 3 resimden 1. How to Fix Thread Tension on a Juki DDL-8700: adım 5, 3 resimden 2. How to Fix Thread Tension on a Juki DDL-8700: adım 5, 3 resimden 3.
    • Create a baseline thread tension for the bobbin case by tightening or loosening the screw on the bobbin case.
    • Thread should not easily unravel but can be pulled loosely.
  6. How to Fix Thread Tension on a Juki DDL-8700: adım 6, 2 resimden 1. How to Fix Thread Tension on a Juki DDL-8700: adım 6, 2 resimden 2.
    • Reinsert the bobbin case into the machine.
  7. How to Fix Thread Tension on a Juki DDL-8700: adım 7, 3 resimden 1. How to Fix Thread Tension on a Juki DDL-8700: adım 7, 3 resimden 2. How to Fix Thread Tension on a Juki DDL-8700: adım 7, 3 resimden 3.
    • Sew another straight line on the scrap fabric next to the previous line.
  8. How to Fix Thread Tension on a Juki DDL-8700: adım 8, 3 resimden 1. How to Fix Thread Tension on a Juki DDL-8700: adım 8, 3 resimden 2. How to Fix Thread Tension on a Juki DDL-8700: adım 8, 3 resimden 3.
    • Check the front and back thread tension of the scrap fabric for loose stitches.
  9. How to Fix Thread Tension on a Juki DDL-8700: adım 9, 3 resimden 1. How to Fix Thread Tension on a Juki DDL-8700: adım 9, 3 resimden 2. How to Fix Thread Tension on a Juki DDL-8700: adım 9, 3 resimden 3.
    • Adjust the upper thread tension.
    • If there are loose stitches on the top of the fabric, loosen the upper thread tension by turning the tension knob counterclockwise.
    • If there are loose stitches on the bottom of the fabric, tighten the upper thread tension by turning the tension knob clockwise.
  10. How to Fix Thread Tension on a Juki DDL-8700: adım 10, 3 resimden 1. How to Fix Thread Tension on a Juki DDL-8700: adım 10, 3 resimden 2. How to Fix Thread Tension on a Juki DDL-8700: adım 10, 3 resimden 3.
    • Check the thread tension by sewing another straight line on the scrap fabric next to the previous line.
  11. How to Fix Thread Tension on a Juki DDL-8700: adım 11, 3 resimden 1. How to Fix Thread Tension on a Juki DDL-8700: adım 11, 3 resimden 2. How to Fix Thread Tension on a Juki DDL-8700: adım 11, 3 resimden 3.
    • The thread tension is correct if there are no loose stitches.
    • Repeat steps 5-8 as needed to achieve a consistent thread tension without loops on top or bottom of scrap fabric.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Brandon Mammon
214 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 1-9, Vidal-Chiesa Fall 2024 UC Davis, Team 1-9, Vidal-Chiesa Fall 2024 üyesi
UCD-VIDAL-CHIESA-F24S1G9
2 Üyeler
1 Kılavuz yazıldı
1Rehber Yorum
اَلسَلامُ عَلَيْكُم وَرَحْمَةُ اَللهِ وَبَرَكاتُهُ‎
yar khan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 80
Her zaman: 890
