Ana içeriğe geç
How to Fix Warped LEGO Baseplates
Neye ihtiyacın var
  1. How to Fix Warped LEGO Baseplates, How to Fix Warped LEGO Baseplates: adım 1, 1 resimden 1.
    • Grab a pot large enough to place the LEGO baseplate in.
    • Fill the pot full of tap water, enough to submerge the baseplate completely.
  2. How to Fix Warped LEGO Baseplates: adım 2, 3 resimden 1. How to Fix Warped LEGO Baseplates: adım 2, 3 resimden 2. How to Fix Warped LEGO Baseplates: adım 2, 3 resimden 3.
    • Place the pot of water on a stove.
    • Turn the stove burner on to medium heat.
    • Heat the water to approximately 100 degrees Fahrenheit. Use a thermometer to ensure proper heat.
    • Do not heat water near or above a temperature of 140 degrees Fahrenheit to avoid damaging/melting the plastic.
  3. How to Fix Warped LEGO Baseplates: adım 3, 3 resimden 1. How to Fix Warped LEGO Baseplates: adım 3, 3 resimden 2. How to Fix Warped LEGO Baseplates: adım 3, 3 resimden 3.
    • Place the LEGO baseplate in the pot of heated water for 5-7 minutes.
    • Ensure that the LEGO baseplate is fully submerged for the entire heating duration.
  4. How to Fix Warped LEGO Baseplates: adım 4, 1 resimden 1.
    • Turn the stove off and remove the baseplate from the water.
    • Dry the LEGO baseplate using a paper towel.
  5. How to Fix Warped LEGO Baseplates: adım 5, 1 resimden 1.
    • Quickly sandwich the baseplate between two flat baking pans while the baseplate is still warm.
    • You can use any two flat, sturdy objects if baking pans are unavailable.
  6. How to Fix Warped LEGO Baseplates: adım 6, 2 resimden 1. How to Fix Warped LEGO Baseplates: adım 6, 2 resimden 2.
    • Place two plastic clamps over the two pans to evenly apply firm pressure against the baseplate.
    • If clamps are unavailable, you can use weights to apply similar pressure.
    • Leave the LEGO baseplate in between the pressure of the baking pans for at least 5 hours.
Sonuç
If your LEGO baseplate is still warped after the 5 hours of sitting in between the clamps, repeat process and leave the LEGO baseplate in between clamps for an additional 5 hours.
2 farklı kişi bu kılavuzu tamamladı.
Nicole DeFer
203 İtibar
1 Kılavuz yazıldı
Ekip
CSU Fullerton, Team 1-5, Bruce Fall 2022 CSU Fullerton, Team 1-5, Bruce Fall 2022 üyesi
CSUF-BRUCE-F22S1G5
2 Üyeler
2 adet Kılavuz yazıldı
Bir Yorum
100 degrees doesn't seem hot enough.
michael kithcart - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 31
Son 30 gün: 98
Her zaman: 2,531
