Ana içeriğe geç
How to Fix Xbox One Wireless Controller Drift
Neye ihtiyacın var
  1. How to Fix Xbox One Wireless Controller Drift, How to Fix Xbox One Wireless Controller Drift: adım 1, 1 resimden 1.
    • Remove the batteries from the controller.
    • If you are using a wired controller, disconnect the wire.
  2. How to Fix Xbox One Wireless Controller Drift: adım 2, 3 resimden 1. How to Fix Xbox One Wireless Controller Drift: adım 2, 3 resimden 2. How to Fix Xbox One Wireless Controller Drift: adım 2, 3 resimden 3.
    • Pour 70% isopropyl alcohol on the tip of a cotton ball.
    • Keep the item away from children and avoid touching your face and open wounds while using it.
  3. How to Fix Xbox One Wireless Controller Drift: adım 3, 2 resimden 1. How to Fix Xbox One Wireless Controller Drift: adım 3, 2 resimden 2.
    • Rub the cotton ball all along the edges of the thumbstick.
  4. How to Fix Xbox One Wireless Controller Drift: adım 4, 1 resimden 1.
    • Let the controller dry for 40-60 seconds.
    • Repeat Steps 2-4 two more times or until the thumbstick no longer drifts.
  5. How to Fix Xbox One Wireless Controller Drift: adım 5, 3 resimden 1. How to Fix Xbox One Wireless Controller Drift: adım 5, 3 resimden 2. How to Fix Xbox One Wireless Controller Drift: adım 5, 3 resimden 3.
    • Connect your controller and see if there are any drift stick problems on any game.
Sonuç
After fixing the controller, if there are any more problems, later on, repeat the same process to have it working again.
11 farklı kişi bu kılavuzu tamamladı.
Julian Echevarria
363 İtibar
1 Kılavuz yazıldı
Ekip
10 Yorum
would hand sanitizer be a good substitute?
just me - Yanıt
Personally wouldn't recommend using hand sanitizer. IPA of various concentrations is already cheap and readily available in every pharmacy section, or a can of WD-40 Specialist Contact Cleaner is also around $5. In theory, hand sanitizer would "work" if it's ethanol/isopropyl alcohol based, but there's such a broad range of hand sanitizers, it would be irresponsible to make a blanket statement that they're all safe/unsafe for electronics. For example, many brands include fragrances, moisturizers, vitamin-E, etc. to keep your hands from excessively drying out, which can end up leaving residue and gumming up your electronics' contacts further.
SPARTAN VI -
I had actually been dumb enough not to look this up, so I just replaced the thumb sticks and it had made it better, but it didn't fix it. Any recommendations? I've had the controller since around 2016 or 2017. Original controller that came with the xbox.
Chill Doggo - Yanıt
The original Xbox one controller is notorious for getting stick drift. Only way to fix that one is the re-Solder the thumb stick back on. Like remove it and re-solder it.
Carlos Ramos -
THANK YOU!!!! Bruh….thank you.
Nick Ikombe - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 204
Son 7 gün: 1,281
Son 30 gün: 5,811
Her zaman: 149,663
