Ana içeriğe geç
How to Fix a Broken Ceramic Vase
Neye ihtiyacın var
  1. How to Fix a Broken Ceramic Vase, How to Fix a Broken Ceramic Vase: adım 1, 1 resimden 1.
    • Examine the damage to the vase. Determine how large the cracks and chips are.
    • Smaller cracks can be fixed with a ceramic adhesive, while larger cracks may require putty.
  2. How to Fix a Broken Ceramic Vase: adım 2, 1 resimden 1.
    • Sand the broken edges and cracked pieces on the vase with a sander block.
  3. How to Fix a Broken Ceramic Vase: adım 3, 2 resimden 1. How to Fix a Broken Ceramic Vase: adım 3, 2 resimden 2.
    • Apply ceramic adhesive to the broken pieces and press them together for two minutes.
  4. How to Fix a Broken Ceramic Vase: adım 4, 1 resimden 1.
    • Secure masking tape over the cracks and let the vase dry for 3 hours.
  5. How to Fix a Broken Ceramic Vase: adım 5, 1 resimden 1.
    • After the vase dries, clean the areas with a cloth where chunks of ceramic are missing.
  6. How to Fix a Broken Ceramic Vase: adım 6, 2 resimden 1. How to Fix a Broken Ceramic Vase: adım 6, 2 resimden 2.
    • Use a chisel scraper to fill in the missing areas with putty and allow it to dry completely.
  7. How to Fix a Broken Ceramic Vase: adım 7, 1 resimden 1.
    • Select a paint that matches the vase and use a soft paintbrush to paint the dry putty wall.
  8. How to Fix a Broken Ceramic Vase: adım 8, 1 resimden 1.
    • Let the paint dry for one hour on the vase and your repair is finished.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 34
Son 30 gün: 145
Her zaman: 1,212
