Ana içeriğe geç
How to Fix a Broken Ceramic Vase
Neye ihtiyacın var
  1. How to Fix a Broken Ceramic Vase, How to Fix a Broken Ceramic Vase: adım 1, 1 resimden 1.
    • Examine the damage to the vase. Determine how large the cracks and chips are.
    • Smaller cracks can be fixed with a ceramic adhesive, while larger cracks may require putty.
  2. How to Fix a Broken Ceramic Vase: adım 2, 1 resimden 1.
    • Sand the broken edges and cracked pieces on the vase with a sander block.
  3. How to Fix a Broken Ceramic Vase: adım 3, 2 resimden 1. How to Fix a Broken Ceramic Vase: adım 3, 2 resimden 2.
    • Apply ceramic adhesive to the broken pieces and press them together for two minutes.
  4. How to Fix a Broken Ceramic Vase: adım 4, 1 resimden 1.
    • Secure masking tape over the cracks and let the vase dry for 3 hours.
  5. How to Fix a Broken Ceramic Vase: adım 5, 1 resimden 1.
    • After the vase dries, clean the areas with a cloth where chunks of ceramic are missing.
  6. How to Fix a Broken Ceramic Vase: adım 6, 2 resimden 1. How to Fix a Broken Ceramic Vase: adım 6, 2 resimden 2.
    • Use a chisel scraper to fill in the missing areas with putty and allow it to dry completely.
  7. How to Fix a Broken Ceramic Vase: adım 7, 1 resimden 1.
    • Select a paint that matches the vase and use a soft paintbrush to paint the dry putty wall.
  8. How to Fix a Broken Ceramic Vase: adım 8, 1 resimden 1.
    • Let the paint dry for one hour on the vase and your repair is finished.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
What kind of putty do you use?
Jill Martin Ward - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 36
Son 30 gün: 172
Her zaman: 4,776
