Ana içeriğe geç
How to Fix a Broken Necklace Chain
Neye ihtiyacın var
  1. How to Fix a Broken Necklace Chain, How to Fix a Broken Necklace Chain: adım 1, 2 resimden 1. How to Fix a Broken Necklace Chain, How to Fix a Broken Necklace Chain: adım 1, 2 resimden 2.
    • Examine the break.
    • If there is an open link in the chain, skip to step three.
  2. How to Fix a Broken Necklace Chain: adım 2, 3 resimden 1. How to Fix a Broken Necklace Chain: adım 2, 3 resimden 2. How to Fix a Broken Necklace Chain: adım 2, 3 resimden 3.
    • Use the needle nosed pliers to separate the closure of a link on one side of the break.
    • You do not need this step if your necklace already has an open link.
  3. How to Fix a Broken Necklace Chain: adım 3, 2 resimden 1. How to Fix a Broken Necklace Chain: adım 3, 2 resimden 2.
    • Hook the closed link opposite the break to the open link.
  4. How to Fix a Broken Necklace Chain: adım 4, 3 resimden 1. How to Fix a Broken Necklace Chain: adım 4, 3 resimden 2. How to Fix a Broken Necklace Chain: adım 4, 3 resimden 3.
    • Using the needle nosed pliers, squeeze the ends of the open link together.
    • Make sure the closed link is inside the open link.
  5. How to Fix a Broken Necklace Chain: adım 5, 1 resimden 1.
    • Using the needle nosed pliers, squeeze the closure so that the ends of the link are flush with one another.
  6. How to Fix a Broken Necklace Chain: adım 6, 2 resimden 1. How to Fix a Broken Necklace Chain: adım 6, 2 resimden 2.
    • Test the closure by gently pulling it from either side. If it comes apart repeat steps 4 and 5.
Sonuç
Now you're ready to flaunt your old necklace once again!
35 farklı kişi bu kılavuzu tamamladı.
Bethany Smith
1.329 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 30-5, Green Spring 2015 Cal Poly, Team 30-5, Green Spring 2015 üyesi
CPSU-GREEN-S15S30G5
5 Üyeler
32 adet Kılavuz yazıldı
13 Yorum
My chain broke when my 7 year old cousin pulled on it when he was piggy back ridding me. Ha Ha. Only took 20 min to do this. Very easy bit best to have nimble and dexterous fingers
Melvin Ricks - Yanıt
My very new chain had broken a day after my birthday .. and the chain is very special so of course I was panicking trying to figure out how to fix it . I found this website and i fixed it within 10 minutes.
Bethany - Yanıt
With the smaller necklaces, the broken link always falls off really easily, is there a way to make that easier to fix?
Angela Wei - Yanıt
My costly gold chain break down...as it is very lin... How can I joint it
Kunalsam 007 - Yanıt
I would like to say that my gold chain down due to its thinness...how can I joint this chain
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 153
Son 7 gün: 892
Son 30 gün: 3,658
Her zaman: 455,177
