Giriş
Do you have an old chain bracelet or necklace that broke, but you still want to keep? Old accessories can always be restored to its original functionality. This guide will provide you with a step-by-step process for fixing broken chains.
Neye ihtiyacın var
Locate the broken link.
Place the pliers on the right of the small opening on the chain.
"Identify the smaller and wider hole on the soda tab. Make a small cut along the edge towards the center of the hole."
Specify which hole you're cutting.
This creative guide can be used for all accessories whether big or small, wide or thin. Now you can restore old, broken, accessories that still have a special place in your heart.
4 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Always great to be able to repair and reuse broken jewelry. A tip on how to add a bright, metal jump ring or chain to an older, more tarnished necklace is to use the flame of a wooden match to burn the newer metal. It will give it an antique look. Try doing it on just one bit of metal to see how it reacts. And, always hold the metal with your pliers, not your hands, when you're burning it. Allow it to cool. Wipe off excess tarnish with a tissue. Note: this needs a wooden match, not a lighter.
Also, to polish sterling chains, you can use a q-tip with fireplace ashes. They work great!
Fixed a broken chain bracelet with your method!
Thanks a bunch :)
