Giriş
In this fix we will be learning how to fix a broken pipe with materials you can find laying around without having to buy a whole new pipe. In many homes this is a very common issue, water pipes often break and people end up buying a whole new pipe. In order to help the environment it is essential that we use the resources we have to their fullest potential, this is an easy fix, like it happens with pipes water hoses are often thrown away when they start leaking. Here we can use an old hose in order to fix the broken pipe and I will show you how.
Neye ihtiyacın var
Make sure the adapter fits the broken end of the water pipe by fitting the adapter without the sealing glue. (Just in case it is not the correct measurement.)
