Ana içeriğe geç
How to Fix a Broken Wig
Neye ihtiyacın var
  1. How to Fix a Broken Wig, How to Fix a Broken Wig: adım 1, 2 resimden 1. How to Fix a Broken Wig, How to Fix a Broken Wig: adım 1, 2 resimden 2.
    • Brush out the wig with a comb. Use a brush if the wig is severely tangled.
    • Do not brush aggressively as you may tear out more pieces of the wig.
  2. How to Fix a Broken Wig: adım 2, 3 resimden 1. How to Fix a Broken Wig: adım 2, 3 resimden 2. How to Fix a Broken Wig: adım 2, 3 resimden 3.
    • Lay out the weft so it is not in a clump.
    • Comb out the weft so it is not tangled.
  3. How to Fix a Broken Wig: adım 3, 3 resimden 1. How to Fix a Broken Wig: adım 3, 3 resimden 2. How to Fix a Broken Wig: adım 3, 3 resimden 3.
    • Mount the wig on somewhere secure.
    • Clip up the hair out of the way of the damaged spot with hair clips.
  4. How to Fix a Broken Wig: adım 4, 2 resimden 1. How to Fix a Broken Wig: adım 4, 2 resimden 2.
    • Line up wefts where you want to fill the damaged spot.
  5. How to Fix a Broken Wig: adım 5, 3 resimden 1. How to Fix a Broken Wig: adım 5, 3 resimden 2. How to Fix a Broken Wig: adım 5, 3 resimden 3.
    • Pin the lined up wefts in place with the pins so they don’t move around while working.
    • Use caution when working with pins and needles so you do not poke yourself.
  6. How to Fix a Broken Wig: adım 6, 2 resimden 1. How to Fix a Broken Wig: adım 6, 2 resimden 2.
    • Thread a needle with a long strand of thread.
    • Double it over by pulling the needle to the middle of the thread, then bring both ends together to knot them.
  7. How to Fix a Broken Wig: adım 7, 3 resimden 1. How to Fix a Broken Wig: adım 7, 3 resimden 2. How to Fix a Broken Wig: adım 7, 3 resimden 3.
    • Sew the weft in at each of the non-elastic bands of the wig in the damaged area.
    • An overhand stitch (also called a whip stitch) is easy and works well for this fix.
    • Be sure to tie off any loose ends after you are done stitching.
    • If you need help with the stitch, here is a helpful link with instructions.
  8. How to Fix a Broken Wig: adım 8, 3 resimden 1. How to Fix a Broken Wig: adım 8, 3 resimden 2. How to Fix a Broken Wig: adım 8, 3 resimden 3.
    • Take out the pins and check to see if there is still damage and another weft is needed.
    • If the damage is still noticeable, repeat steps 1-8 with another weft. If not, you are ready to use your wig again!
  9. How to Fix a Broken Wig: adım 9, 2 resimden 1. How to Fix a Broken Wig: adım 9, 2 resimden 2.
    • With a completed wig, you are ready to shine your best out to the world.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Reid Dounias
172 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S2-G3, Bender Fall 2018 UC Davis, Team S2-G3, Bender Fall 2018 üyesi
UCD-BENDER-F18S2G3
2 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 28
Her zaman: 924
