Giriş
The soldered connections in the average XLR cable can break under heavy use. Use this guide to disassemble an XLR connector and resolder the broken connection.
Neye ihtiyacın var
Place the end of the XLR Cable on a clean, uncluttered surface.
Using a small screwdriver, unscrew the single screw near the top of the cable.
Gently pull apart the exterior metal from the internal mechanism.
4 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Great repair. If the cabke is broken I have a video on resolving that issue. https://youtu.be/E8CiX4cnc-U
