Ana içeriğe geç
How to Fix a Broken Zipper
Neye ihtiyacın var
  1. How to Fix a Broken Zipper, How to Fix a Broken Zipper: adım 1, 3 resimden 1. How to Fix a Broken Zipper, How to Fix a Broken Zipper: adım 1, 3 resimden 2. How to Fix a Broken Zipper, How to Fix a Broken Zipper: adım 1, 3 resimden 3.
    • Take the needle nose pliers and remove the metal or plastic stopper at the end of the zipper.
    • Zip the zipper all the way down to the last set of teeth.
  2. How to Fix a Broken Zipper: adım 2, 3 resimden 1. How to Fix a Broken Zipper: adım 2, 3 resimden 2. How to Fix a Broken Zipper: adım 2, 3 resimden 3.
    • Align both sides of the zipper evenly and slip the zipper back on track.
  3. How to Fix a Broken Zipper: adım 3, 3 resimden 1. How to Fix a Broken Zipper: adım 3, 3 resimden 2. How to Fix a Broken Zipper: adım 3, 3 resimden 3.
    • Start zipping up the zipper to make sure it has been aligned properly.
  4. How to Fix a Broken Zipper: adım 4, 3 resimden 1. How to Fix a Broken Zipper: adım 4, 3 resimden 2. How to Fix a Broken Zipper: adım 4, 3 resimden 3.
    • Thread the needle.
    • Sew up the area where the metal or plastic stopper used to reside.
  5. How to Fix a Broken Zipper: adım 5, 3 resimden 1. How to Fix a Broken Zipper: adım 5, 3 resimden 2. How to Fix a Broken Zipper: adım 5, 3 resimden 3.
    • Tie off what has been sewn by making a knot in the thread.
  6. How to Fix a Broken Zipper: adım 6, 2 resimden 1. How to Fix a Broken Zipper: adım 6, 2 resimden 2.
    • Take the scissors and cut off the excess thread. Get as close to the knot as you can without cutting it off.
  7. How to Fix a Broken Zipper: adım 7, 3 resimden 1. How to Fix a Broken Zipper: adım 7, 3 resimden 2. How to Fix a Broken Zipper: adım 7, 3 resimden 3.
    • Zip up the garment to make sure everything is working properly.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Not helpful. Suppose if the slider part broke and is now now. Now what?
Walter Nagel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 21
Son 30 gün: 105
Her zaman: 4,295
