Ana içeriğe geç
How to Fix a Carabiner
Neye ihtiyacın var
  1. How to Fix a Carabiner, How to Fix a Carabiner: adım 1, 1 resimden 1.
    • Position the carabiner so that the gate is pushed forward past the nose and the latch is hanging out.
  2. How to Fix a Carabiner: adım 2, 1 resimden 1.
    • Position the pliers between the rivet pin.
    • The rivet pin is a flat rectangle metal piece poking out of the hinges.
  3. How to Fix a Carabiner: adım 3, 1 resimden 1.
    • Gently but firmly squeeze the rivet pin behind the hinge.
  4. How to Fix a Carabiner: adım 4, 2 resimden 1. How to Fix a Carabiner: adım 4, 2 resimden 2.
    • Push the gate back, so that it is behind the nose.
    • Be sure to push the gate slowly and carefully, to avoid unnecessary jerking around, which could potentially break the carabiner further.
  5. How to Fix a Carabiner: adım 5, 1 resimden 1.
    • Position the gate back to the original position behind the nose.
  6. How to Fix a Carabiner: adım 6, 1 resimden 1.
    • The gate should now snap back into position securely. If it does not, repeat the process.
    • Be sure that the rivet pin was not bent or broken in the act of guiding the gate back to its original position.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Thank you for tutorial I was autism and bent it.
Vehicular manslaughter - Yanıt
Was gonna throw the old one away but this helped. Good as new now, thanks!
Maksim Krotov - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 129
Son 30 gün: 568
Her zaman: 19,115
