Ana içeriğe geç
How to Fix a Chair Armrest
Neye ihtiyacın var
  1. How to Fix a Chair Armrest, How to Fix a Chair Armrest: adım 1, 3 resimden 1. How to Fix a Chair Armrest, How to Fix a Chair Armrest: adım 1, 3 resimden 2. How to Fix a Chair Armrest, How to Fix a Chair Armrest: adım 1, 3 resimden 3.
    • Remove the armrest from the chair using a hex wrench screwdriver and a drill to remove the screws.
    • You can also use a screwdriver instead of a drill.
  2. How to Fix a Chair Armrest: adım 2, 2 resimden 1. How to Fix a Chair Armrest: adım 2, 2 resimden 2.
    • This is the chair that we will fix, and the armrest that was broken.
  3. How to Fix a Chair Armrest: adım 3, 2 resimden 1. How to Fix a Chair Armrest: adım 3, 2 resimden 2.
    • Sand just the inside tip of the armrest as shown.
  4. How to Fix a Chair Armrest: adım 4, 2 resimden 1. How to Fix a Chair Armrest: adım 4, 2 resimden 2.
    • Apply a little bit of glue on the part that you sanded.
    • It is fine if you do not want to use glue.
  5. How to Fix a Chair Armrest: adım 5, 2 resimden 1. How to Fix a Chair Armrest: adım 5, 2 resimden 2.
    • Put the screw washer on the screw.
  6. How to Fix a Chair Armrest: adım 6, 3 resimden 1. How to Fix a Chair Armrest: adım 6, 3 resimden 2. How to Fix a Chair Armrest: adım 6, 3 resimden 3.
    • Insert the screw inside the hole on the inside of the chair body.
    • Have another person attach the armrest and then screw it with your hand.
  7. How to Fix a Chair Armrest: adım 7, 2 resimden 1. How to Fix a Chair Armrest: adım 7, 2 resimden 2.
    • Insert the screw into the end of the armrest, attaching it to the edge of the back of the chair using a drill.
    • You may also use a screwdriver instead of a drill.
  8. How to Fix a Chair Armrest: adım 8, 3 resimden 1. How to Fix a Chair Armrest: adım 8, 3 resimden 2. How to Fix a Chair Armrest: adım 8, 3 resimden 3.
    • Tighten up the screw with a hex wrench screwdriver.
  9. How to Fix a Chair Armrest: adım 9, 2 resimden 1. How to Fix a Chair Armrest: adım 9, 2 resimden 2.
    • All done! Now your armrest should feel securely attached to the chair.
Sonuç
These are moderate step to fix your chair armrest.
Bir başkası bu kılavuzu tamamladı.
Deviny
196 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 55
Her zaman: 2,456
