Ana içeriğe geç
How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard
Neye ihtiyacın var
  1. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard, How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: adım 1, 3 resimden 1. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard, How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: adım 1, 3 resimden 2. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard, How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: adım 1, 3 resimden 3.
    • Unplug the cord from the wall and the back of the keyboard.
  2. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: adım 2, 3 resimden 1. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: adım 2, 3 resimden 2. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: adım 2, 3 resimden 3.
    • Flip over the keyboard.
    • Check the battery holder and remove the battery cover.
    • Remove all outer screws with a Philips screwdriver. These are the 19.0 mm Philips screws.
    • Remove the middle screw and the middle top screw. They are the 25.4 mm Philips screws.
  3. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: adım 3, 1 resimden 1.
    • Carefully remove the cover, and set it aside.
    • Find the contact pad.
  4. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: adım 4, 3 resimden 1. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: adım 4, 3 resimden 2. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: adım 4, 3 resimden 3.
    • At the top of the contact pad, carefully pinch the black clamps closed.
    • Once all the clamps are closed, wiggle the contact pad free.
    • Be careful of the small black hooks at the bottom.
  5. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: adım 5, 1 resimden 1.
    • After the contact pad is free, gently lift it up.
  6. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: adım 6, 3 resimden 1. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: adım 6, 3 resimden 2. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: adım 6, 3 resimden 3.
    • Vacuum and/or gently wipe the dust away.
  7. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: adım 7, 1 resimden 1.
    • Place the contact pad back gently.
  8. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: adım 8, 1 resimden 1.
    • Place the cover back on.
    • Place the screws back in.
    • The 25.4mm Philips screws go in the middle and top middle. The 19mm screws go around the case.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sydney Schuett
211 İtibar
1 Kılavuz yazıldı
Ekip
Bir Yorum
This is a good pictorial guide to how the keyboard works and how to service it, I used electronic switch cleaner {aerosol} on a cloth to clean the contacts and it was successful leaving all the keys working.
jeff may - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 52
Her zaman: 3,008
