Ana içeriğe geç
How to Fix a Delta 5-Function Showerhead Model 75554
Neye ihtiyacın var
  1. How to Fix a Delta 5-Function Showerhead Model 75554, How to Fix a Delta 5-Function Showerhead Model 75554: adım 1, 3 resimden 1. How to Fix a Delta 5-Function Showerhead Model 75554, How to Fix a Delta 5-Function Showerhead Model 75554: adım 1, 3 resimden 2. How to Fix a Delta 5-Function Showerhead Model 75554, How to Fix a Delta 5-Function Showerhead Model 75554: adım 1, 3 resimden 3.
    • Unscrew the head of the shower from the pipe with a pipe wrench.
    • While using the pipe wrench, make sure not to clamp it too tight because it will crack the plastic.
  2. How to Fix a Delta 5-Function Showerhead Model 75554: adım 2, 2 resimden 1. How to Fix a Delta 5-Function Showerhead Model 75554: adım 2, 2 resimden 2.
    • Fill a large bowl with equal parts hot water and white distilled vinegar to get rid of hard water build up.
  3. How to Fix a Delta 5-Function Showerhead Model 75554: adım 3, 2 resimden 1. How to Fix a Delta 5-Function Showerhead Model 75554: adım 3, 2 resimden 2.
    • With the tip of a pocketknife, pick out the rubber, black washer in the attachment.
    • Using your fingertips press a new 1" black rubber washer into the head attachment. The new washer will allow water to flow correctly with more pressure.
    • Pocketknives can be very very sharp!
  4. How to Fix a Delta 5-Function Showerhead Model 75554: adım 4, 2 resimden 1. How to Fix a Delta 5-Function Showerhead Model 75554: adım 4, 2 resimden 2.
    • Wipe down with shower pipe with a hot water and vinegar soaked scrub brush.
  5. How to Fix a Delta 5-Function Showerhead Model 75554: adım 5, 2 resimden 1. How to Fix a Delta 5-Function Showerhead Model 75554: adım 5, 2 resimden 2.
    • Wrap Teflon tape around the legs of the spout about 3 times to ensure that it will screw on tight when the head is put back on.
    • Now is the time to take the shower head out of the vinegar water.
  6. How to Fix a Delta 5-Function Showerhead Model 75554: adım 6, 3 resimden 1. How to Fix a Delta 5-Function Showerhead Model 75554: adım 6, 3 resimden 2. How to Fix a Delta 5-Function Showerhead Model 75554: adım 6, 3 resimden 3.
    • Twist the shower head back onto the pipe and tighten it with the pipe wrench.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Faith Henson
160 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 25
Her zaman: 1,511
