Giriş
Suitcases can be an expensive investment, so nothing is worse than when your suitcase is damaged and all you can worry about is the amount of money you’ll have to spend on a new one. This guide will help you remove the harsh dents from your suitcase, so you may use it again, without worrying about buying a new one. This guide uses items that are easily accessible such as a hairdryer and a screwdriver, so that you don’t have to spend any more money. Another benefit is that this guide can be completed quickly, so your suitcase can look better in no time.
Be cautious when using a hair dryer to heat your suitcase. Applying heat to one area for too long can melt the material and damage your luggage. When checking the heated area, use heat-resistant gloves to avoid burns. Additionally, remember that while this guide helps to remove the dent, the outcome may not restore the suitcase to its original appearance, especially if it has a textured hard case. As shown in this guide, the ridges around the previously dented area have smoothed out a bit.
Neye ihtiyacın var
