Ana içeriğe geç
How to Fix a Dirty Censor in a Corsair Harpoon RGB
Neye ihtiyacın var
  1. How to Fix a Dirty Censor in a Corsair Harpoon RGB, How to Fix a Dirty Censor in a Corsair Harpoon RGB: adım 1, 2 resimden 1. How to Fix a Dirty Censor in a Corsair Harpoon RGB, How to Fix a Dirty Censor in a Corsair Harpoon RGB: adım 1, 2 resimden 2.
    • Start by flipping the mouse over to view the flat side of the mouse.
    • Remove the mouse feet to reveal the screws holding the bottom and top part of the mouse together.
  2. How to Fix a Dirty Censor in a Corsair Harpoon RGB: adım 2, 3 resimden 1. How to Fix a Dirty Censor in a Corsair Harpoon RGB: adım 2, 3 resimden 2. How to Fix a Dirty Censor in a Corsair Harpoon RGB: adım 2, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the screws that hold the mouse together.
    • Once the screws are removed, pull the mouse apart by holding the top and bottom pieces.
    • The mouse will be pulled into two pieces: the top (rounded part) and bottom (flat part).
  3. How to Fix a Dirty Censor in a Corsair Harpoon RGB: adım 3, 1 resimden 1.
    • After the mouse has been pulled apart, the flex cable will be visible. This must be removed before continuing.
    • To remove the flex cable, gently pull the cable clip until it becomes unlatched.
  4. How to Fix a Dirty Censor in a Corsair Harpoon RGB: adım 4, 2 resimden 1. How to Fix a Dirty Censor in a Corsair Harpoon RGB: adım 4, 2 resimden 2.
    • Remove the motherboard. The motherboard is mounted on the mouse, so gently remove by simply pulling the motherboard from within the mouse.
  5. How to Fix a Dirty Censor in a Corsair Harpoon RGB: adım 5, 2 resimden 1. How to Fix a Dirty Censor in a Corsair Harpoon RGB: adım 5, 2 resimden 2.
    • Once the motherboard is removed, the optical sensor will be fully exposed. This is the piece that is causing the lag in the mouse.
    • The optical sensor is dirty, and needs to be gently cleaned with a Q-tip or soft cloth dipped in 90% isopropyl alcohol.
Sonuç
To disassemble, clean, and reassemble your mouse, follow these guidelines.
3 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Muy buena guia. Me fue muy util. Gracias y saludos.
Bolzano - Yanıt
why did you opened it if you just cleaned eye with alcohol
antoncoinz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 48
Son 30 gün: 175
Her zaman: 6,064
