Ana içeriğe geç
How to Fix a Feather Cat Toy
Neye ihtiyacın var
  1. How to Fix a Feather Cat Toy, How to Fix a Feather Cat Toy: adım 1, 2 resimden 1. How to Fix a Feather Cat Toy, How to Fix a Feather Cat Toy: adım 1, 2 resimden 2.
    • Slide a crimp onto the cat toy's line.
    • Thread the line through the ring of the key clasp.
    • You should have a small loop formed at the end of the line.
  2. How to Fix a Feather Cat Toy: adım 2, 2 resimden 1. How to Fix a Feather Cat Toy: adım 2, 2 resimden 2.
    • Slide the crimp down to close the loop. Make sure that the crimp covers each part of the line.
    • Use your crimping tool or pliers in order to secure the crimp.
  3. How to Fix a Feather Cat Toy: adım 3, 1 resimden 1.
    • Apply super glue to any cracks visible on the feather capsule for maximum security.
    • Let the feather capsule piece dry entirely before proceeding to the next step.
  4. How to Fix a Feather Cat Toy: adım 4, 1 resimden 1.
    • Use regular glue to fill the inner portion of the feather capsule.
    • Fill it up only halfway in order to leave enough space for feathers.
  5. How to Fix a Feather Cat Toy: adım 5, 2 resimden 1. How to Fix a Feather Cat Toy: adım 5, 2 resimden 2.
    • Individually insert the quill of each feather into the capsule.
    • Work quickly so that the glue doesn’t dry and cause the feathers to stick in the wrong direction.
  6. How to Fix a Feather Cat Toy: adım 6, 1 resimden 1.
    • Press down on the clasp lever to open up the hinge.
    • Slide the loop on the feather connector into the clasp to reconnect the toy.
Sonuç
Repeat the instructions in this guide every time your cat breaks their toy!
Bir başkası bu kılavuzu tamamladı.
Isabella Markell
148 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 1-6, Whithaus Spring 2024 UC Davis, Team 1-6, Whithaus Spring 2024 üyesi
UCD-WHITHAUS-S24S1G6
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 13
Son 30 gün: 34
Her zaman: 391
