Ana içeriğe geç
How to Fix a Flexi Leash
Neye ihtiyacın var
Videoya Genel Bakış
  1. How to Fix a Flexi Leash, How to Fix a Flexi Leash: adım 1, 1 resimden 1.
    • Place the object in a clear bright space.
  2. How to Fix a Flexi Leash: adım 2, 3 resimden 1. How to Fix a Flexi Leash: adım 2, 3 resimden 2. How to Fix a Flexi Leash: adım 2, 3 resimden 3.
    • Start by removing all the 0.5 cm screws off the leash with the Phillips #0 screwdriver.
  3. How to Fix a Flexi Leash: adım 3, 3 resimden 1. How to Fix a Flexi Leash: adım 3, 3 resimden 2. How to Fix a Flexi Leash: adım 3, 3 resimden 3.
    • Using a plastic opening tool, begin to separate the top and bottom of the leash.
    • Make sure to press lightly to prevent unwanted marks.
    • It is most likely that the brake button will fall out. Place small items to the side to prevent it from being lost or undetected.
  4. How to Fix a Flexi Leash: adım 4, 2 resimden 1. How to Fix a Flexi Leash: adım 4, 2 resimden 2.
    • Carefully remove the brake mechanism. Inside should be a small spring.
    • Remove and replace the spring with a new one.
    • When placing the break mechanism back into its place, make sure the spring is positioned right in the middle.
  5. How to Fix a Flexi Leash: adım 5, 3 resimden 1. How to Fix a Flexi Leash: adım 5, 3 resimden 2. How to Fix a Flexi Leash: adım 5, 3 resimden 3.
    • When the spring is successfully placed, initiate the retraction to it's original position.
    • Make sure the top and the bottom are aligned properly.
    • Slowly press the top and the bottom of the leash until it returns to its initial position.
  6. How to Fix a Flexi Leash: adım 6, 3 resimden 1. How to Fix a Flexi Leash: adım 6, 3 resimden 2. How to Fix a Flexi Leash: adım 6, 3 resimden 3.
    • Finish by screwing the 0.5 cm screws in their original position.
Bitiş Çizgisi
Bir Yorum
Where do i buy the spring?
Andrew Storeck - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 29
Son 30 gün: 96
Her zaman: 4,000
