Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the dust covers on both sides (drive side and non-drive side) of the crankset with a flathead screwdriver by turning it counterclockwise.
Remove the crank bolts on either side of the crankset by using the 14 mm drive socket to spin the bolts counterclockwise.
Screw the head of crank extractor into the dust cover hole by hand until it is snug.
Screw the handle of the crank extractor into the head.
Rotate the handle of the crank extractor clockwise until the crank arm is completely loose from the bottom bracket, then remove the crank arm.
Unscrew the handle and head of the crank extractor from the crank arm and repeat the process on the other side.
On the left side (non-drive side) of the bike, place the notch of the lock ring wrench into one of the divots on the lock ring.
Ensuring that the curve of the wrench is pressed against the lock ring, turn the lock ring counterclockwise.
Screw out the left side (non-drive side) bottom bracket cup by placing a pin spanner into the holes on the face of the cup and turning counterclockwise.
Remove the spindle and the ball bearings on both sides.
Clean every component including the ball bearings, spindle, bottom bracket cup and inside the frame.
Inspect the spindle. If you see significant pitting on the surface where the ball bearings would spin, you may want to replace it with a new spindle.
Apply a lot of bike grease on the ball bearings and inside of the right (drive side) bottom bracket cup.
Insert the spindle with the excessively greased drive side ball bearings.
Apply grease on the other bearing balls, and put it onto the spindle with the bearing cage facing outwards.
Apply a generous amount of grease to the inside of the left side bottom bracket cup.
Put a light amount of grease on the threads of bottom bracket cup, and screw it into the shell by hand.
Adjust the tightness of the non-drive side cup until the spindle spins freely without resistance, but all of the play is eliminated from the spindle. If the spindle moves up and down, you want the cup more tight, and if the spinning doesn't feel smooth, you want to loosen it a bit.
After making sure the cup has the right tightness (the spindle can turn smoothly without play), hold the cup in place with the pin spanner and use your hands to screw on the lock ring by turning it clockwise.
Then, using the pin spanner to hold the cup in place, tighten the lock ring using the lock ring wrench.
Thoroughly clean any excess grease off of the spindle.
Install the right side (drive side) crankset first, and rotate it 180 degrees to install the left side (non-drive side).
2 farklı kişi bu kılavuzu tamamladı.
