Ana içeriğe geç
How to Fix a Hole In Wall
Neye ihtiyacın var
  1. How to Fix a Hole In Wall, Dry wall: adım 1, 3 resimden 1. How to Fix a Hole In Wall, Dry wall: adım 1, 3 resimden 2. How to Fix a Hole In Wall, Dry wall: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use pliers (or tweezers if the hole is very small) to clean out hole by removing the drywall out of the hole.
  2. How to Fix a Hole In Wall: adım 2, 1 resimden 1.
    • Use scissors to cut drywall mesh.
    • To ensure that the entire hole is covered, cut a piece of mesh larger than the size of the hole.
  3. How to Fix a Hole In Wall: adım 3, 2 resimden 1. How to Fix a Hole In Wall: adım 3, 2 resimden 2.
    • Use a damp sponge to apply moisture to make the mesh stick to the wall, covering the entire hole.
  4. How to Fix a Hole In Wall: adım 4, 3 resimden 1. How to Fix a Hole In Wall: adım 4, 3 resimden 2. How to Fix a Hole In Wall: adım 4, 3 resimden 3.
    • Use a drywall knife to apply the drywall compound over the mesh. Make sure to spread a generous amount over the entire mesh.
    • Let the compound dry for about 30 minutes.
    • You can speed up the drying process by placing a fan directly in front of the drying compound.
  5. How to Fix a Hole In Wall: adım 5, 1 resimden 1.
    • Once compound is dry, use sandpaper to smooth out the entire surface of the dried compound.
  6. How to Fix a Hole In Wall: adım 6, 3 resimden 1. How to Fix a Hole In Wall: adım 6, 3 resimden 2. How to Fix a Hole In Wall: adım 6, 3 resimden 3.
    • Paint over the surface with a paint brush.
    • Use paint that matches the rest of the wall for best results.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Darrian Johnson
304 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Oi! como faço reboca que a parede está pintada branca?
dezinho anderson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 17
Son 30 gün: 116
Her zaman: 7,192
