Ana içeriğe geç
How to Fix a Hole in Leggings by Hand Sewing
Neye ihtiyacın var
  1. How to Fix a Hole in Leggings by Hand Sewing, How to Fix a Hole in Leggings by Hand Sewing: adım 1, 3 resimden 1. How to Fix a Hole in Leggings by Hand Sewing, How to Fix a Hole in Leggings by Hand Sewing: adım 1, 3 resimden 2. How to Fix a Hole in Leggings by Hand Sewing, How to Fix a Hole in Leggings by Hand Sewing: adım 1, 3 resimden 3.
    • Use scissors to cut a piece of thread that is the color of your leggings at least 12 inches long.
  2. How to Fix a Hole in Leggings by Hand Sewing: adım 2, 1 resimden 1.
    • Mishandling of the needle could result in minor or moderate injury.
    • Thread the needle by running the piece of thread through the eye, or opening, of the needle.
  3. How to Fix a Hole in Leggings by Hand Sewing: adım 3, 1 resimden 1.
    • Pull the thread through the needle until there are two equal halves of thread.
    • Tie a knot with the ends of the thread.
  4. How to Fix a Hole in Leggings by Hand Sewing: adım 4, 1 resimden 1.
    • Turn the leggings inside out.
    • This is so the sewing will be on the inside of the leggings.
  5. How to Fix a Hole in Leggings by Hand Sewing: adım 5, 1 resimden 1.
    • Smooth out the fabric around the hole.
  6. How to Fix a Hole in Leggings by Hand Sewing: adım 6, 1 resimden 1.
    • Pinch the fabric together.
    • Begin your stitch on one end of the hole.
  7. How to Fix a Hole in Leggings by Hand Sewing: adım 7, 1 resimden 1.
    • Use short stitches so that the thread will not break easily.
    • Make sure the hole is completely included in the stitches.
  8. How to Fix a Hole in Leggings by Hand Sewing: adım 8, 1 resimden 1.
    • Tie a knot using the tied ends of the thread (at the beginning of the hole) and the thread still attached to the needle (at the end of the hole).
    • Make sure the knot is large enough so it doesn't slip through the stitches.
  9. How to Fix a Hole in Leggings by Hand Sewing: adım 9, 1 resimden 1.
    • Cut the loose thread above the new knot with scissors.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 25
Son 7 gün: 119
Son 30 gün: 765
Her zaman: 42,247
