Giriş
If your pant pocket has been ripped- damaged, or has a hole in it, use this guide to fix the hole in the pocket.
The pocket in your pant help keep your important possessions like phone, key. A ripped pocket will allow all your possessions to fall get damaged and can lead to loss.
Before using this guide make sure you have some knowledge of sewing with a double stitch method.
Step 4 requires you to insert pins in the traced area you want to sew. This would help create holes. From there you would need to sew the ripped portion using a needle and thread.
Before beginning, make sure to flip the pocket in and out.
Neye ihtiyacın var
